09-26-2007, 04:39 PM | #1 |
stroker kits
who's the best people to buy 383 stroker kits from price wise/ quality wise. I'm looking to get one for an early Christmas present for myself.
thanks
1972 C10 Custom Deluxe Longbed Fleetside (currently apart in the garage) '69 C10 Custom Deluxe Shortbed Fleetside (all original, including the brown recluses!) 1990 C1500 Shortbed Sportside |
09-26-2007, 05:37 PM | #2 |
Re: stroker kits
There is a very inexpensive kit through Powerhouse in CA or a good kit at a fair price through Syummit for about $900.
09-26-2007, 05:39 PM | #3 |
Re: stroker kits
eagle here's a link
http://www.eaglerod.com/products/Che...ssemblies.html
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
09-26-2007, 06:29 PM | #4 |
Re: stroker kits
This is where I got my kit. Fast shipping and no problems at all. Has brand name stuff.....
http://www.gofaststuff.com/index.html
1997 GMC Sierra Ext 1965 Mustang |
09-26-2007, 08:36 PM | #5 |
Re: stroker kits
make sure you get h beam rods if your going to run a oversize cam or rod bolts will hit the cam on standard I beam rods . jmo
bob
I BELIEVE IN JOHN 3:16 |
09-26-2007, 08:45 PM | #6 |
Sierra Grande Club
Re: stroker kits
+1 for the internally balanced eagle kit.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
09-26-2007, 11:01 PM | #7 | |
Re: stroker kits
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
09-27-2007, 10:56 AM | #8 |
Re: stroker kits
I forget excactly how much you can remove but not much is needed and no need for rebalance if you weigh each rod and take the same off each one using a scale as you go
