Runaway horn
Just replaced my signal cancelling cam, put my steering wheel back on, hooked the battery up and now my horn will not stop blowing. Replaced the relay thinking maybe it was stuck, but no luck. I have a late 80's wheel on it and it has worked fine for a long time. Any ideas?...David
72 Cheyenne Super 402 daily driver. A lifetime project! |
Re: Runaway horn
sounds like the insulator(nylon circle with 3posts) and flexplate thing (brass looking the 3lugs of insulatorgo thru the holes) is installed improperly/// or the black wire inside the column got grounded out when installing the cam// easy way to tell is take of the wheel and if the horn is still blowin its in the column if it stops its in the wheel mechanism
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 09-26-2007 at 05:45 PM. |
Re: Runaway horn
I think I pinched the black wire ....will try again.
