Old 09-26-2007, 05:52 PM   #1
epsorenson
epsorenson's Avatar
How to keep my doors from closing
another question....forgive me if it's brainless but i'm new at all this.
my doors (driver/passenger) don't stay open.
always close on me, especially when i'm parked on incline.
seems like a simple fix...what specifically do i need to get to remedy this?
thanks
"Some days you're the bug....Some days you're the windshield"
71 Blazer K5
epsorenson is offline   Reply With Quote
Old 09-26-2007, 05:58 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: How to keep my doors from closing
The good - Sounds like the hinges are wore out.
The bad - Alot of the repop hinges are junk
The solution - Get a rebuild kit from a Vendor
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-26-2007, 05:59 PM   #3
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
Sounds like you need a new check link.
Hard Luck is offline   Reply With Quote
Old 09-26-2007, 06:03 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Hard Luck, are you talking about the part in the middle of the hinge?
I forgot about that part Epsorenson, it has plastic guides, I think
*EDIT - just went out and looked on GQ, they look kinda plasticish
Old 09-26-2007, 06:30 PM   #5
epsorenson
epsorenson's Avatar
great....thanks guys
71 Blazer K5
Old 09-26-2007, 06:35 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Hope we helped, if not we will be here when you come back and ask again
Old 09-26-2007, 06:53 PM   #7
jaros44sr
jaros44sr's Avatar
Good answer guys, that rebuild kit should fix it...
on your 25,000th
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-26-2007, 07:55 PM   #8
zeusflash
zeusflash's Avatar
You will also probably need the friction pads that rub on the check link since they are usually not included in the rebuild kits. These pieces can get worn down so thin that they barely touch the check link. These are available throught the usual chevy truck parts houses(they are a little pricey).
'69 3/4 ton 427 CST Pickup
'71 CST Blazer
'72 GMC 3/4 4x4
zeusflash is offline   Reply With Quote
Old 09-27-2007, 02:19 PM   #9
epsorenson
epsorenson's Avatar
sorry to be a pest.
i'm having trouble figuring out the vendor thing.
can you guys tell me which vendor is near me in so cal that i can order the re-build kit from?
71 Blazer K5
Old 09-27-2007, 02:31 PM   #10
Burt4x4
Burt4x4's Avatar
www.brotherstrucks.com is in so cal I belive..
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-27-2007, 03:22 PM   #11
epsorenson
epsorenson's Avatar
thanks!
yeah they are in so cal.
their website doesn't have the rebuild kit listed but i'll give em a call.
71 Blazer K5
Old 09-27-2007, 03:37 PM   #12
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
You can pick up a Door Stop at Home Depot for like 2 bucks.
Angelse68cal is offline   Reply With Quote
Old 10-12-2007, 02:26 PM   #13
epsorenson
epsorenson's Avatar
hey there guys...i'm still not having any luck with this.
can only find the entire hinge for sale.
can't seem to locate rebuild kit with check link/friction pads.
can anyone help?
thanks again
71 Blazer K5
Old 10-12-2007, 05:53 PM   #14
jaros44sr
jaros44sr's Avatar
can anyone help?
thanks again
How about Classic Industries, I used to buy alot of parts from them. They are in Huntington Beach, Ca. Where ever that is
SAFETY FIRST
AS usual, off topic
Jim
Old 10-12-2007, 05:59 PM   #15
epsorenson
epsorenson's Avatar
Originally Posted by jaros44sr View Post
How about Classic Industries, I used to buy allot of parts from them. They are in Huntington Beach, Ca. Where ever that is
thanks, just called em...no dice though.
they referred me to "hemmings" which seems to be a parts finding source.
anyone else?
71 Blazer K5
Old 10-12-2007, 06:11 PM   #16
jaros44sr
jaros44sr's Avatar
anyone else?
Might have to bite the bullet and buy Hinges, altho, that plastic pc. shouldn't be to hard to make. I just looked at mine, seems simple enuff
SAFETY FIRST
AS usual, off topic
Jim
Old 10-12-2007, 06:16 PM   #17
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Call Wes at http://classicheartbeat.com/. He's knows his stuff and can find the parts you need.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-18-2007, 03:31 PM   #18
epsorenson
epsorenson's Avatar
just called wes...also said he has the hinges only.
seems like the check link/friction pads are almost impossible to get by themeselves
71 Blazer K5
Old 10-20-2007, 06:37 PM   #19
jaros44sr
jaros44sr's Avatar
just dug out an old set of hinges, seems like those friction blocks would be easy to make. All you have to do is knock out one roll pin and the whole gizmo falls apart. So you have to take the hinges off to get at the parts, why not buy a couple of used hinges off the classified, rebuild them and slap them on. Then you could sell your old hinges to the next guy with the same problem... JAT J.
SAFETY FIRST
AS usual, off topic
Jim
