Old 09-26-2007, 09:05 PM   #1
Pyrotechnic
Pyrotechnic's Avatar
Steering Boxes
Were there different steering boxes that came in these trucks from the factory ? Reason I ask is because on the RPO sheet in the glove box, it says something to the effect of "Variable Ratio Steering." If you guys need the code and the exact wording I can go look but I was wondering if anyone knew off the top of their head.
Pyrotechnic is offline   Reply With Quote
Old 09-27-2007, 11:04 AM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Steering Boxes
There was the factory manual steering and the power steering with varible ratio. There was only 1 power steering box though. Standard was the manual.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-27-2007, 02:39 PM   #3
Pyrotechnic
Re: Steering Boxes
Thanks. I have another question. Did the crew cab trucks have more wheel cut than the regular cab trucks ? Reason I ask, I find the amount of wheel cut on my longbed just barely adequate for most parking situations. I can't imagine the extra few feet of a crew cab being maneuverable at all with the same amount of wheel cut.
Old 09-27-2007, 04:19 PM   #4
454HO
Re: Steering Boxes
I don't think the amount of turn is limited by the steering box. There is a hard mechanical stop (ie interferance) between the spindle and the lower control arm that limits the amount of turn angle.
- Greg
454HO is offline   Reply With Quote
Old 09-27-2007, 10:33 PM   #5
1975stepside
Stepside Fanatic!
Re: Steering Boxes
I know 4x4's have different steering boxes than 2 wheel drive. But I don't recall if that was for manual steering or power steering.
1975stepside is offline   Reply With Quote
Old 09-27-2007, 11:35 PM   #6
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: Steering Boxes
Dunno about different steering boxes, but the pitman arm is different - pointing straight back on 2wd models, and towards the passenger side on the 4x4 trucks - that's why switching a 4x4 over to crossover steering linkage involves installing a 2wd steering box or at least a 2wd pitman arm.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 09-28-2007, 12:14 PM   #7
Captkaos
Captkaos's Avatar
Re: Steering Boxes
Same box on all 2WD's. 4x4's use a different box setup, but it is still variable ratio.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 09-28-2007, 02:52 PM   #8
Pyrotechnic
Re: Steering Boxes
So a crew cab long bed wouldn't have any more turn angle than a regular cab short bed ?
