Old 09-26-2007, 11:13 PM   #1
ofnaman
ofnaman's Avatar
need some more help please! suspension
I am wanting to buy drop spindles for my '70 3/4 ton. I have not found any yet for the 3/4 ton's. My question is can I put spindles on it off of a '71 or '72 1/2 ton without changing the a arms? I know I will need to change to disk brakes and all of that stuff, but are the a arms the same? If not can I use 1/2 ton a arms without changing the crossmember? Anyone done this? Thank you.
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 09-27-2007, 03:18 AM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: need some more help please! suspension
Bump for you
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-27-2007, 03:34 AM   #3
67 cst swb
67 cst swb's Avatar
If I remember correctly, 3/4T & 1/2T control arms are different (ball joint hole larger on bottom arm) But, I think you have 2 options... you can use all the 1/2T stuff (spindles, brakes, control arm upper & lower) they bolt right onto your crossmember. OR you can use 73-79 3/4T spindles. you may need to change ball joints, but the new ball joints will fit directly into your control arms. Double check at a parts store to be sure the original (70 3/4T) ball joints outside diameter may be the same as 73-79, it's just the taper of the threaded part is different. You may need to change outer tie rod ends also. The complete steering linkage set-up from either 71-72 or 73-79 will bolt in directly. PM me with any more questions.
Hope this helps.
Some one else chime in if I'm wrong here, please.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 09-27-2007, 03:38 AM   #4
67 cst swb
67 cst swb's Avatar
Originally Posted by ofnaman View Post
.... If not can I use 1/2 ton a arms without changing the crossmember?
Yes,...
My Trucks:
