Old 09-27-2007, 01:39 AM   #1
04 orange
04 orange's Avatar
Z'ed frame and lower radiator hose
What are you guys doing about a lower radiator hose on your trucks that have a z'ed frame. I've tried using a flex hose and that pinches at the water pump neck, the stock hose almost pinches when it goes over the frame, and I've tried about ten other hose and none will work. Guess I'm going to have to make something out of a few hoses. Anybody got any part numbers or ideas.
04 orange is offline   Reply With Quote
Old 09-27-2007, 03:55 AM   #2
impala_631
:( BYEBYE :(
impala_631's Avatar
Re: Z'ed frame and lower radiator hose
i made mine out of two hoses, part stock 74 lower hose and part 69 upper and i small peice of pipe,i also notched the frame a lil bit, it sounds rigged but its been like that for over two years with no problems
impala_631 is offline   Reply With Quote
Old 10-04-2007, 12:19 AM   #3
bigtruck81
i was also going to suggest a solid metal "hose" like some of the pre-73 trucks used, with short sections of rubber at either end.
bigtruck81 is offline   Reply With Quote
