Old 10-01-2002, 10:38 PM   #1
68_GMC_910
what would Neal do?
68_GMC_910's Avatar
putting an M22 Rockcrusher in my truck...
and I'm wondering what I'm going to have to do to fit it in right now... anyone do this before? anyone seen this before? anyone got a link to a site that did this?
1968 GMC 910 Long Step 250/3onTree
1969 Chevy C10 longfleet, 350/350
68_GMC_910 is offline   Reply With Quote
Old 10-01-2002, 10:57 PM   #2
crazy longhorn
Fabricate till you "puke"
I ran an M 21 in a 71 c10, it was pretty much a bolt in(same lenght as a 3 spd saginaw). your m 22 will have a 26 spline input shaft,& a 32 spline out put. You will need to change the clutch due to spline, & the slip yolk will need to be changed. The pilot hole in the bell will be to large to center the trans properly.......you can us a 67 or prior bell to get the proper hole size,or pick up a ring to press on the input collar. If using the truck bell, you will need to bolt & nut the bottom 2 ears on the trans,as the bolts go from the inside,& screw into the 3 spd trans. other than that, just cut a hole in the floor& hang the shifter. good luck.......crazy AL
crazy longhorn is offline   Reply With Quote
Old 10-01-2002, 11:28 PM   #3
68_GMC_910
what would Neal do?
68_GMC_910's Avatar
Thanks.
