Old 04-30-2002, 03:37 AM   #1
katoom27
Post split rim to tubeless rim
I have a 67 C-30 dump with split rims in not so good shape. What (dually) tubeless rims will fit correctly? Thanks in advance.
Kip
katoom27 is offline   Reply With Quote
Old 04-30-2002, 04:22 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
I would think just about any 8 bolt dually wheel would fit well, but i don't know about the later models, something about metric studs and smaller hubs.
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-30-2002, 09:11 PM   #3
ddsmith
Glowing since 1978
ddsmith's Avatar
Post
I believe you have half inch studs on your 67 truck. At least my 66 C30 has them. The wheels for mid 80's trucks will fit. The important part is the size of the hub pilot hole which actually centers the wheel. These wheels are designed for 9/16" studs but I put them on my truck. You could attempt to use spacer between the studs and the wheels but why bother. They do not center the rims the hub pilot does. The stud nuts are there to make sure the wheel doesn't come off. Look at your lug nuts. I think you have the nut that is flat on the back side which contacts the rim and are split on the outer edge to provide a anti backoff feature.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
79 Chevy 4X4 (Tom's old truck)
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 04-30-2002, 09:26 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
Post
those are the wheelnuts he will have, the locking flat ones, most all 70-older have 1/2" studs and most all 71-up are 9/16" studs
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
-71 C-10 350/CH465/3.07, basketcase literally, am assembling now
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, dammit,,
-82 purple Trans Am, ram hood, junk305/good THM200C
**I buy/sell/hoard/trade most any GM vehicle parts of any and all kinds
-parting out: '81 Cutlass Supreme Brougham
*Paint is overrated
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 05-01-2002, 07:23 AM   #5
katoom27
Post
Yes, they are 1/2" with split nuts. Did you use mid 80's Chevy, or just measure the hole I.D. and off to the junkyard? What about the offset of the rim?
Unfortunately mine doesn't have the original 327.
Thanks Kip
Old 05-02-2002, 05:35 AM   #6
ddsmith
Glowing since 1978
ddsmith's Avatar
Post
I borrowed a friends spare from his mid 80's truck to check size and found a set of four on ebay for sale. Cost $105 but shipping killed me. I went to the junkyard but wasn't happy with anything they had available. The one my friend let me borrow was bought new from GM dealer. I think I may have some more info on my computer andd I'll see if I can e-mail it sometime soon. I think that Firestone was the manufacturer off alot of the rims and finding info on old numbers is a little hard. Talk to you later.
