Old 09-27-2007, 10:37 PM   #1
Orange
Licensed to Thrill!
Orange's Avatar
Building rear tank - what do I need?
OK, so I got my measurements and am having my aluminum tank built.
Basically the same as any other metal tank out there.
My only thing is I want to make sure I do everything right.
I have my sending unit on the way (universal 5 hole pattern 0-90 ohm).
I have my location for the filler figured out. ( http://www.classicheartbeat.com/mark...t_gas_door.htm )
I will be using a vent at the filler (see above link) - do I need any other venting?
One question I have - it is apparently against federal regulations to use a bottom mounted pickup (saw it today here: http://www.tanksinc.com/index.cfm/pa...prod/prd83.htm)
So, how do I go about doing that? (Using a mechanical pump of course). And, where do I get what I need.
What else do I need?
Thanks.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 09-27-2007, 10:55 PM   #2
67 cst swb
67 cst swb's Avatar
Re: Building rear tank - what do I need?
I purchased the pick-up tube assy from Tanks inc (I'm running their tank) plus a couple other things for about $36.00... but, I'm sure their pick-up will only work with 9-1/2" deep tanks...
I can get you a picture of it next week. I'm sure it would be easy to build, especially if your able to build a aluminum tank.
Also, there are thousands of racing fuel cells out there on the streets with bottom/rear feed fuel lines. I would put mine in the rear bottom of the tank if I were building my own.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 09-27-2007, 11:39 PM   #3
brak
brak's Avatar
Originally Posted by Orange View Post
...One question I have - it is apparently against federal regulations to use a bottom mounted pickup (saw it today here: http://www.tanksinc.com/index.cfm/pa...prod/prd83.htm)
Thanks.
DLB
I'm pretty sure what they are referring to are fuel cells like the one pictured below, which are not designed or legal for street use. They are inteded for offroad use only. If you are using a standard style sending unit you should be fine.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 09-28-2007, 08:09 AM   #4
Orange
Licensed to Thrill!
Orange's Avatar
Bryan - I have seen the pickup tubes, and if that's all that's needed, then I could do that no problem. But if brak is right, then bottom mounted would be better anyhow. I may look into that just little farther.
DLB
Old 09-29-2007, 04:46 PM   #5
67 cst swb
67 cst swb's Avatar
If your sending unit has a pick up tube in it. I'm not familiar of any aftermarket sending units that have pick ups in them. But, I'm not as knowledgeable as I used to be to new products out there. I haven't worked behind the counter selling auto parts for 6 years now (Whew!!!!!)
My Trucks:
