Old 09-28-2007, 01:20 AM   #1
65chevypickupguy
65chevypickupguy's Avatar
Transmission mount on 65 chevy
I installed a turbo 400 behind my SBC and just kind of guested on how to align it as far as up and down. It's cobbled together and I would like to know the proper way to set the tranny in place. I've positioned it in two places and both seem to work OK. Do I need the driveline set to a certain angle in relation to the rear end? Also, does someone make a bolt-in aftermarket transmisison mount?
Mark
65chevypickupguy is offline   Reply With Quote
Old 09-28-2007, 09:56 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Transmission mount on 65 chevy
Mark
If you have the stock crossmember from an automatic truck you can just use that with a stock 400 tranny mount. I believe the Th350,400, and 700R4's all use the same mount.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-28-2007, 10:14 AM   #3
QWYKTRUK
Check this out- click on link and scroll down to trans mounts.CP9427 should do it.
http://www.classicperform.com/6092chevtrk.htm
QWYKTRUK is offline   Reply With Quote
Old 09-28-2007, 03:07 PM   #4
Iron-Butt
454 club
Iron-Butt's Avatar
I just put a turbo 400 behind my 454. All I did was slide the stock transmission crossmember back and drilled new holes in the frame. I was having a new driveshaft made becuase of going from the 235 to the 454.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
