09-28-2007, 10:53 AM | #1 |
PITbut
Tire dilema. Need some help.
Currently my truck is running 235/75/15 now. I have a set of rallys that are 15x10. The tires on the rallys are 295/50/15. The rallys sit about 2 inches lower then the 235s on there now. That means when im on the freeway im going to be revving much higher along with being 2 inches lower.
I cant seem to find a tire that can get me the overall diameter that i need. I need a minimum of a 29" diameter tire to maintain what i have now. Not many tires want to fit over a 15x10 inch rim. The 295/50/15s have an overall diameter of 28"/ But when you put them on a 10 inch wide rim, that changes quite a bit...ahaha... I dont want to sell my rallys... Any suggestions on tire size?? Its going on a 71 stepside.... Im just looking for some advice. |
09-28-2007, 11:40 AM | #2 |
Re: Tire dilema. Need some help.
Try & find a set of BFG's in 285-70-15. They'll work well on the 10's & have the height your wanting. The problem is it's a discontinued size so it will take some searching (but they're still out there).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-28-2007 at 11:40 AM. |
09-28-2007, 11:44 AM | #3 | |
PITbut
295/50/15 off the rim is 28" Well, you put those 295/50/15 on a ten inch rim and that 28" is a litlte smaller... Id say its about 1.5" overall difference... THe truck seems to sit about 2 inches lower then it did.. I will get pics on here. I will look for a 285/70 right now.... |
09-28-2007, 11:47 AM | #4 |
Out of the carpool lane.
Check The Tire Rack. www.tirerack.com
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
09-28-2007, 11:54 AM | #5 | |
PITbut
cooper tires tire rack discount tire goodyear LTR republic dunlop pacemark bluestreak. HAHAH... Im going to just put the tires on and drive it.. The main concern is with the 235/75/15s currently on the vehicle, when on the freeway doing 65 im PEGGED out..... With these 295/50's on there i think doing 55 is going to be pushing it. |
09-28-2007, 01:15 PM | #6 |
I have a radical idea!
255/70/15's are what you need. That's I used to run them on my '78 GMC. They are 29.1" on a 8" rim, but I have run the on 10's, and they do fine. The tread width is around 10" so they are going to bow in a little. There just isn't a lot of wide tires in a 15" that measures much taller than 28".
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
09-28-2007, 01:27 PM | #7 | |
Does it have to be a 10" rear wheel? Run 8" wheels out back w/the 255-70's & you'll save some RPM's on the hwy & it will look good too.
09-28-2007, 01:30 PM | #8 | |
I agree it's pushing it on a 10" rim, but he already has the 10" rallys and he wants to use them.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 09-28-2007 at 01:31 PM. |
09-28-2007, 01:43 PM | #9 | |
PITbut
I have to go with the 10" rears. Thats what i have and i need to make that work... As a kid i have always wanted deep rallys on my classic if i ever got one and i finally got one... I think the 265/70/15's will be even better... Thank you... I might have a set of those bad boys in stock. |
09-28-2007, 02:00 PM | #10 | |
09-28-2007, 02:04 PM | #11 |
PITbut
Ever since i was a kid i always remember two things about classics.. I loved rallys on big fat tires, and i loved the 396 badge... So when i was buying this truck seeing it came with a free set of 15x10 rallys with all the fixins i was sold.. Now i just need to find my 396 or 454 and im set. ahah.
09-28-2007, 02:13 PM | #12 |
I,m running 295/50/15 on 10'' wheels they are almost 27'' tall.
09-28-2007, 02:16 PM | #13 | |
PITbut
Now that im thinking about it... Isnt a 15x10 wheel on the front going to look kind of odd?? I might have to get a different rally for the front.. I dont like the front rims sticking out ya know... I should just say **** it and get my 22" rears and 20" fronts and call it a day.... |
09-28-2007, 02:33 PM | #14 | |
Just go with 295's and get an OD tranny!
09-28-2007, 02:51 PM | #15 |
PITbut
Well, the motor is an inline six with 3 speed manual on the floor right now... I will be getting motor and trans setup but not at least for a year im guessing....
Ahh crap.. I just looked at the front tires... Fronts now are 235/75/15 and the rally tires are 265/50/15.... Heres the specs on those Results Overall Diameter: 3.5" difference Circumference: 11" differnce Thats going to PANCAKE the front of my truck. ahaha... Anyone have a pic of a 15x10 front rim on our trucks??? |
09-28-2007, 06:18 PM | #16 |
I am going to be running into the same delimia on my 67. A buddy of mine gave me a set of 295/50/15s and I think they will be to short.
If you do some looking on summitracing.com they have sizes like, 295/60/15 295/65/15 315/60/15 325/50/15 345/55/15 I belive all of the sizes I've seen in these sizes are DOT Street Drag Radials from Hoosier, Mickey Thompson, Goodyear, BFGoodrich, and I think there was even on by Nitto. I'll probably go with something like these.
www.fatdaddieshotrods.com |
09-28-2007, 06:20 PM | #17 |
what is the widest you could go on an 8 inch wheel I am running 275 60 15 now
sorry to jack the thread Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
09-28-2007, 08:46 PM | #18 | |
"Taste It"
Here ya go 15X10s all the way around 265/50/r15 front 295/50/r15 rear I like the way it looks B
71 Chevrolet short fleet Cheyenne air cab/tilt w buddy buckets pretty stock other wise. 2007 Silverado Crew with the MAX Pack and loaded 2007 CX-9 "Hopefully when I die.. my wife wont sell my stuff for what I said I paid for it" It's easier to ask forgiveness than it is to ask permission. |
09-29-2007, 08:53 PM | #19 | |
PITbut
Here is the finished rallys. Anyone need a set??? WIW? |
02-02-2012, 07:11 PM | #20 | |
02-02-2012, 09:09 PM | #21 | |
http://www.cokertire.com/brands/bf-g...blackwall.html
02-02-2012, 09:24 PM | #22 |
Yeah, this one is old !
http://www.jegs.com/i/Coker-Tire/257...ductId=1123896 In stock and ready to go.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
