Has anyone moved their pedals for more room?
I did alot of driving in Low Buck this last week (300 mile trips for work) and found that I am getting older or just warn out but my knee's start to ache and I need to move my pedals forward a few inches. I hope toget about 3" out of the pedals and 3" by getting a new bench seat or have mine re worked to thin out the back. I have room in th eengine bay to cut the pedal box and relocate parts of it forward. Then I would need to modify the brake pedal to set it back 3" along with bending the gas pedal some as well. Has anyone done anything like this or other mods for more leg room short of streaching the cab or getting a different vehical?
Kevin LFD Inc. |
Out of the carpool lane.
Re: Has anyone moved their pedals for more room?
Kevin, moving the pedals is too easy for you, I think you should do this instead:
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#3 | |
![]() Kevin LFD Inc. |
Overdrive club
Best pedal modification i did was eliminating the clutch pedal
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
That's right, it's Copper!!
I'm in the process of assembling the inside of my truck. I've been working with the pedal mounts for a few hours now and I can't think how you would move them without redesigning everything.
Good luck, let us know how you do it! |
its all about the +6 inches
If you have relocated the fuel tank, you can trim the back wall where the seat hits it, so the seat can go back further. (remounting the seat is required) You'd have to do something about the sharp edge left there, but that should be fairly easy to come up with something on that though.
I mounted my seat up a little higher in the front, so, it sits down lower in the rear, which lets my legs come to rest higher in the front of the seat... it helped a good bit. Not perfect, but more comfortable to drive. I don't feel like I'm constantly holding my leg up in the air anymore, but I could still use more leg room.
Doesn't need to be a sharp edge. This mod can add about three inches of leg room
Just be aware that moving the seat back put your head closer to the back glass
Used Register
Maybe you could retro-fit the electric adjustable pedals from the later trucks (some Fords had them).
Herb |
#11 | ||
Kevin LFD Inc. |
Truck and auto performance nut
my seat back is also fairly thick, probably 4.5-5". I've often thought if I had one of the thinner ones I'd gain some legroom.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#13 |
![]() Join Date: Nov 2006
I'm eager to see the achievement...so hurry up!
Hey...when did low buck get a LT1 and 700r? I didn't see that thread! |
#14 |
Burnouts are therapeutic
I Adjusted Rod That Goes To Brake Booster And Got Mine About 2 Inches Closer To Floor ,now I Don't Have To Pull Knee Into Chest To Hit Brake Pedal.......mine Does Have Disc Conv. Kit On It So It May Be Different.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
#15 |
I should qualify that trimming the lip around the fuel tank will only be useful under 2 conditions 1) the fuel tank is removed from the inside of the cab, and 2) the thick backed stock seat is replaced with a seat that has a thinner back and is positioned where it will fit under the rear window. There is a wide range of seats that will fit without much work.
#16 |
#17 |
[QUOTE=ebfabman;2379610]Doesn't need to be a sharp edge. This mod can add about three inches of leg room
This is exactly what I had in mind to do. Do you have any pics with the seat in?
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug |
