View Poll Results: Which exhaust to use | |||
Magaflow Stainless | 18 | 24.66% | |
Flowmaster | 40 | 54.79% | |
Other | 15 | 20.55% | |
Voters: 73. You may not vote on this poll |
09-28-2007, 03:58 PM | #1 |
Exhaust Poll
Yes, another poll. This time I can't make up my mind on which exhaust system to use. They all have their pros and cons. Either I want the Magnaflow 2.5" stainless system for $500.00 or have another made using 2.5" pipe with Flowmasters for around the same price. Or, what other system is out there? What do you think???
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 09-28-2007 at 04:00 PM. |
09-28-2007, 04:05 PM | #2 |
Re: Exhaust Poll
Sorry not much help the orginal muffler and piping is still on my truck can't believe its in decent shape still after 36 years maybe the 74k helped out some. Looking forward to the results though I will have to change mine when I do the 350 swap.
09-28-2007, 04:14 PM | #3 |
Re: Exhaust Poll
I like the magnaflow sound over the flows myself, I have a magnaflow on my diesel and flows on the 68 and 97, but the flows are coming off, Im actually going to run the hooker aerochamber its a similar design to edelbrocks muffler at a fraction of the cost
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
09-28-2007, 05:21 PM | #4 |
Re: Exhaust Poll
The big question is what do you like better? I personally think the Magnaflow sytem with the x-pipe setup sounds too high pitched and raspy. I klnow a guy with a custom bent 2.25" system with Magnaflow mufflers and no x-pipe and it sounds really nice.
I had a custom built 2.5" system built at a local shop with Flowmaster Super 40's for right at $400.00. It was a bit pricey, but the Super 40's are a little higher than others. I was actually gonna have Magnaflow mufflers installed after hearing the truck stated above because they're not as expensive, but he only had one muffler. I love the way it sounds! The Super 40's have a deep rumble and aren't as loud as original 40 series. You can tell I have a small block in my truck, but you have to really listen to make sure it's not a big block IMO. The Magnaflow system is nice with stainless pipe and mandrel bends, but even after you pay to get it, you still have to pay someone to install it. That is, unless you're pretty savvy with a cutter and welding. The system is made for LWB trucks so it can be fit down for SWB trucks, so it still has to be cut and fitted first. It's also made for headers, so if you're using manifolds, you'll still have to have pipes made to connect them. My vote is for a custom built system with whatever kind of mufflers YOU like.
09-28-2007, 05:47 PM | #5 |
Born Psycho
Re: Exhaust Poll
i've worked in the same muffler shop for over 22 years and i usually judge which muffler to use by the persons age. mid 30s on up i try to sell magnaflows--they're more mellow at cruising speed.late teens up to early 30s usually get flows-- they have a resonance noise at cruising speed that can be annoying to some people.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
09-28-2007, 05:51 PM | #6 |
Re: Exhaust Poll
I will say Flow Masters 40Series I took the afternoon off of work and finished my exhaust. New Heddman Elite Hedders with Dual 2 1/2" Flowmasters with turndowns in front of rearend.
2012 F150 SuperCrew 2011 GMC 1500 (COMPANY TRUCK) 1982 Chevy Blazer 2WD (Work in Progress) |
09-28-2007, 06:27 PM | #7 |
Re: Exhaust Poll
i guess i'm old now........turn downs with flows in "front" of the rearend (deafening). looking for mellow with a good rap when i hammer it, (out da' back).
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
09-28-2007, 07:41 PM | #8 |
67-72 Addict!
Re: Exhaust Poll
Steve- Flowmaster has a U-Fit kit that has been pretty popular considering it's all mandrel bends and over the axle pieces and any configuration you could think of! If you are coming out in front of the wheels it's not worth buying because you will not use much of the kit. http://www.jegs.com/webapp/wcs/store...1_10263:metal:
http://www.classictrucks.com/tech/07...kit/index.html
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-28-2007, 08:44 PM | #9 |
Re: Exhaust Poll
This thread is "exhausting": me.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-28-2007, 08:57 PM | #10 |
Re: Exhaust Poll
09-28-2007, 09:03 PM | #11 |
Re: Exhaust Poll
I voted Magnaflow but I'm not sure what they sound like. "Putting flame suit on before I say this" but flowmasters are on everything and now every car and truck sound the same. Good luck and tell us what you get.
09-29-2007, 01:25 AM | #13 |
Re: Exhaust Poll
I'm running headman long tube 1 3/4'' primary into 2 1/2'' flowmaster 50 series delta flow angled out in front of the rear tires with 2 1/2'' pipes. This is behind a STOUT 388. It sounds great.
09-29-2007, 01:30 AM | #14 |
Re: Exhaust Poll
I think everyone has a certain "special" sound they want to achieve when installing an exhaust system. In my younger days I really liked the exhaust note I got on my 68 Chevelle w/396 running Thrush turbos thru 2.25 in. pipes.
On my truck I went the "cheap alternative" route, and ran 2.5 in. pipes with Summit Racing welded mufflers that turn out just forward of the rear wheel. I have to admit, they sound nice at idle, but are a bit louder than I wanted when I stomp on it.(2500+ rpm)
_____________________________________________ 69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt" 78 C-10 305 TH350 new (old) daily driver 02 Suburban Z71 a.k.a. the family truckster 99 Silverado 1500 Z71 |
09-29-2007, 02:47 AM | #15 |
Re: Exhaust Poll
I've got a 3'' single exhaust series 40 on my suburban that I like the sound of and recently I had a magnaflow put on my 69 GMC which is also a 3'' single. Magnaflow is a lot quieter. Performance, from what I could tell is about the same. Different trucks though. Both small blocks
09-29-2007, 07:23 AM | #16 |
Re: Exhaust Poll
A lot of good info.....I've heard that Magnaflow system sounds like a Ferrari. Can anyone comment on that? I guess that's what might be holding me back from getting that system. I like the idea of a complete stainless setup, and at a good price as Magnaflow.
1997 GMC Sierra Ext 1965 Mustang |
09-29-2007, 08:06 AM | #17 |
laying low
Re: Exhaust Poll
I have forgotten the link but there are a couple of sites out there with sound clips of popular vehicles with different brands of mufflers to compare. Maybe exhaust soundclips.com or something like that. Probably search Magnaflow or Flowmaster and get the link.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
09-29-2007, 08:19 AM | #18 |
Re: Exhaust Poll
Please... no more Flowmasters.
Every truck, SUV, car, 4-wheeler, & quarter horse has a Flowmaster. Stop the madness & go with something that sounds like a classic truck. Go w/ glasspacks..
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
09-29-2007, 09:38 AM | #19 |
WTB this ad
Re: Exhaust Poll
Flowmasters are like Torque Thrust II rims.....There's a reason everone runs em..........They're nice! Here's a sound/vid clip of my K10 shot at Craig's by Putter.
http://s16.photobucket.com/albums/b4...t=MOV00542.flv |
09-29-2007, 03:04 PM | #20 |
Re: Exhaust Poll
I finally posted this last night. I don't have any vids from the outside yet. Here's one of a ride along in my 68. Remember, I have no interior or insulation yet in this video, so it won't be as loud inside the cab after interior is done.
http://videos.streetfire.net:80/vide...b701737824.htm
09-29-2007, 03:15 PM | #21 |
Re: Exhaust Poll
Hey Steve,
I have dual flows w/headers dumping out in front of wheels, 2 1/2" pipes 350 motor. I love the sound at cruising speed, really love it when I hammer it. I get alot of looks when cruising at low speed in parking lots, alot of reverb off of store fronts. Go with the flow in my opinion, which may not amount too much. I think they will sound better with your hedmans on my truck. I know it will look better anyways. Later, Rich |
09-29-2007, 03:21 PM | #22 | |
Re: Exhaust Poll
09-29-2007, 04:51 PM | #23 | |
Re: Exhaust Poll
My vote is for magnaflow because I'm sick of the flows resonance. But the flows do sound wicked at idle and WOT. |
09-29-2007, 05:10 PM | #24 | |
Texas Big Wig
Re: Exhaust Poll
Ok SBC Mine has true dual 3" with Cherry Bomb extreme (single chamber) mufflers dumping out about a foot behind the cab under the bed If I had more compression I could beat you up with loud can you set off car alarms ??? I can |
09-29-2007, 05:16 PM | #25 |
Re: Exhaust Poll
Just rolling by near idle or parking I set them off sometimes I'm switching to 3" with x-over and some quieter mufflers (maybe magnaflow)soon. So you'll have me beat then for sure.
