09-28-2007, 06:00 PM | #1 |
A guy with a truck
Cutting 1/4" plate...
What are you guys using to cut your plate and pipe? Grinder/cut-off wheel seems like it would take forever...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-28-2007, 06:20 PM | #2 |
Re: Cutting 1/4" plate...
I use a plasma cutter. It makes life alot easier. I think you might be able to rent them. If you have alot to cut i would highly recommend it. Cut off wheels work but i have broken alot of them when they get binded up and break so i try not to use them unless i need to.
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
09-28-2007, 07:21 PM | #3 |
i'd use plasma or oxy acetylene
09-28-2007, 07:40 PM | #4 |
Porta bandsaw
09-28-2007, 08:47 PM | #5 |
i've used a cheapass jijsaw with excellent finetooth bimetal blades with good lubrication for the past 40some years dont think of anything else
09-28-2007, 11:43 PM | #6 |
Yellow truck club
I did my c-notch work on my truck with cut off wheels and a jig saw. 1/4" steel was not too hard to cut .
Brian ...
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
09-29-2007, 12:12 AM | #7 |
vise, sawzall and "the torch" blades for 1/4" metal
09-29-2007, 12:45 AM | #8 |
jig saw ... sawzall ... torch ... plasma ... and if all that fails, I gnaw on it with my teeth!
09-29-2007, 03:50 AM | #9 |
A guy with a truck
I thought about using my jigsaw, but didn't think it would be that effective. I'll give that a shot too. Between the 4.5" grinder, 3" die grinder, 7" metal cutting blade in the Skil, and the jigsaw, I'll find what works best for me.
Thanks guys...
09-29-2007, 09:06 AM | #10 |
sometimes i use a combo of cutoff wheel first, then the sawzall to finish it off.
09-29-2007, 01:35 PM | #11 |
A guy with a truck
Yeah, forgot about that one- the sawzall is one of my favorite tools!
09-29-2007, 06:15 PM | #12 |
:( BYEBYE :(
i always used my cutting torch follwed by a pass with a grinder to clean the cuts up, but a plasma is your best bet for shure
09-30-2007, 12:18 AM | #13 |
Outlandish Trends - FL
I'd use a sawzall
-Bret 67 short-fleet sold! |
09-30-2007, 11:33 AM | #14 |
All of the above work fine you got to work with what you have
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
