Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-28-2007, 08:26 PM   #1
damnyankee36
damnyankee36's Avatar
Air Compressor Timer
I forgot to turn off the circuit breaker to my air compressor last night. Well, during the night it turned on, and at some point both connecting rods broke. Since it couldn't build pressure, it ran for who knows how long until I heard it running this morning.
Is there a method or system available to prevent an air compressor running uncontrolled for long periods? I thought of using a timer that could be set to run for, say, 30 minutes every time the compressor starts and resets when the compressor turns off. I think that would be long enough since I don't believe I would ever need to operate the compressor any longer, but if it were unattended, short enough to prevent an uncontrolled run time.
I've searched online, but haven't found anything that has a delay longer than 17 minutes.
Any thoughts?
Thanks!
Larry
damnyankee36 is offline   Reply With Quote
Old 09-28-2007, 08:57 PM   #2
brianthelion02
Overdrive club
brianthelion02's Avatar
Re: Air Compressor Timer
Ouch,most compressors have a pressure switch that turns em off.
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 10-04-2007, 02:19 AM   #3
jimfulco
Wonder if an attic fan timer would work? My attic fan, ~1950 vintage, has a metal control box on the wall that lets you run it for up to an hour or two before it turns itself off automatically. It has an over-ride lever on the bottom so you can turn it on forever if you want to. I don't know what the horsepower rating is, but that type of timer might be what you need. www.mcmaster.com has a good selection of them. Search for timer switch.
jimfulco is offline   Reply With Quote
Old 10-04-2007, 04:42 AM   #4
earl87gta
earl87gta's Avatar
http://www.northerntool.com/webapp/w...70_22938_22938
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-04-2007, 07:28 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Get a sprinkler timer. It doesn't care what it turns off and on.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-04-2007, 08:31 AM   #6
Truckstr
Truckstr's Avatar
Any thoughts?
Thanks!
Larry
I guess I have to ask why it couldn't build pressure. I mean, most air compressors have the auto on at some low pressure limit and back off at the upper end. So, if it came on automatically, why didn't it go back off? Did the pressure switch malfunction?
That said, instead of some timer, I'd put a working low and high pressure on and off switch on it - like the one from Northern Tool pictured above.
Me? I manually turn mine off. Yeah, I've forgotten before, but the upper end pressure cut-off worked like it should.
If the air compressor pump chucked its rods, are you just going to replace that or?
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 10-04-2007, 09:02 AM   #7
Putter
More Cowbell....
Putter's Avatar
I assume he does in fact have the pressure switch, but if both connecting rods broke (think truck motor....no connecting rods = no piston movement = no pressure build up) then there was no pressure to trip the pressure switch.
Why not wire an outlet to work from the light switch. That way, when you are in the shop with the light on, you have air. When you leave, the lights are off....and so is the compressor.
I wired an outlet like that in my new house, so when I leave the laundry, the outlet used for ironing goes dead with the light switch. No chance of leaving the iron HOT.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 10-04-2007, 09:09 AM   #8
Thealien
Thealien's Avatar
I agree. I usually wire a contactor with a 110 volt coil (220 volt compressor) and connect it to the light circuit. Lights are on compressor has power. Lights off no power. In my last house I installed 3 way switches one in the house, and one in the garage to operate the compressor contactor. I had run under driveway air lines and had an air hose connector by the driveway.
Old 10-04-2007, 09:30 AM   #9
Truckstr
Truckstr's Avatar
Yeah, I understand that. But there has to be a reason for the rods to break. Overheating from running and running and running will do it. So, like I say, why did it not trip? Just a malfunctioning pressure switch? A timer would work, no doubt. But it would only be a back-up.
Good idea. Good back-up and protection. Ya just have to be sure of the switch rating. Otherwise you should use a relay. My air compressor runs on 220v. The normal light switch wouldn't work.
Jeff
Old 10-04-2007, 09:31 AM   #10
Truckstr
Truckstr's Avatar
There ya go.
Jeff
