![]() Join Date: Dec 2006
Lubbing the peddle shaft
Mine has been squeaking real bad for years and I've never seen a proceedure for getting some grease up there.Clutch and brake share one shaft but I thought there'd be a zerk fitting/Don't see one.Do I have to remove the shaft to grease it? And "if" I need bushings,is that an easy job? Thanks!
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#2 | |
Happy to be here
![]() Join Date: Mar 2000
Re: Lubbing the peddle shaft
I lub my wife and my truck, and I even lub my dog - don't lub my clutch/ brake shaft though.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
![]() Join Date: Mar 2007
ive been looking for lub in all the wrong places
what i'd try would be to spray real good with wd-40 while working the pedals no lubricating value but will clean out crap then using spray white lithium grease for the actual lubrication
blood type; Retumbo
there are no bushings in there. the metal shaft rides in the plastic firewall mount.
where as the clutch and brake do have replaceable bushings which can still be gotten from the dealer for like $.25 each. |
#7 | |
I've tried shooting wd40 up there and it seems to help for awhile,then it comes back.Guess I'll just splurge and get those two bushings and do 'er up right. To some of you guys above ; I lub bushings.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 09-29-2007 at 10:03 AM. |
""" ......All ya need is LUB..............dant da danta dah""""
WD is worthless in the machinery world. It only gums up stuff, atracts dust and dirt. Use a good aerosol lubbe like Gibbs. www.gibbslubricant.com:) |
I am a Referee of life.
I think I would miss the squeak.I've had three of these trucks as daily drivers and they all have the same squeak.I don't even know if I would be comfortable driving an auto since it wouldn't have the clutch squeak.
I lub my wife and dog and lube my column shifter.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Gotta LUB it!!!
