Old 09-29-2007, 06:08 AM   #1
loader820
brake light
i have a 1982 my brake not working change bulb.an switch stall not working what can it be
loader820 is offline   Reply With Quote
Old 09-29-2007, 07:09 AM   #2
bobbo
Droppin' It Like It's Hot!
bobbo's Avatar
Re: brake light
Check your fuse for the brake lights. If it's good, use a test light to see if you are getting power to the brake light switch. If that is good, check if you are getting power to the bulb socket. They are common for socket problems (corrosion, loose fitting bulbs, etc.) Pretty basic system so not a whole lot there to go bad... Oh, the other possibility is a bad turn signal switch, even though the turn signals work, the brakes may not. May be an open in the switch or wiring...
Robert
Life Member
RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09
1969 1500
Norwood, MO 2007
Big Sandy, TN 2008 Had nothing to do with the forklift!
Kirkwood, MO (Midwest Meet 2009)
Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014
SUPPORT THE SITE HERE!
bobbo is offline   Reply With Quote
