09-29-2007, 06:58 PM | #1 |
Nuetral safety switch questions - Free Hurst shifter
When I bought my blazer it had a Hurst floor shifter (automatic) and it would start in any gear. The previous owner must have removed the neutral safety switch. This weekend I ripped out the floor shifter and replaced all of the original linkage to make it a column shifter again, but I’m not sure were the neutral safety switch is or was. I assume it would be wired in line of my ignition switch, is that true? Any info would help. Thanks. BTW if anyone in the Sacramento area wants a dual gate Hurst floor shifter come and get it for free. All linkage included. I will not ship it.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
09-29-2007, 07:22 PM | #2 |
Re: Nuetral safety switch questions - Free Hurst shifter
The N\S switch should be screwed to the upper side of the steering column near the firewall.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-29-2007, 07:27 PM | #3 |
I agree...if you lay down on the floor of your truck it should be on the top of the steering colum about 6 inches away from the firewall....maybe a little more or less
09-29-2007, 07:38 PM | #4 |
I think I see what you are talking about. I found a V shaped plug with a light green and a green wire to it. It is not hooked up. I also saw a plug (2 female spade) with two larger purple wires that was disconnected from ?? and jumped across (w/ 2 male spade).
09-29-2007, 07:44 PM | #5 |
Yep those are the wires. The purple ones go on the right and the green goes on the left. The plugs on the safety switch face the driver. I told you the order they go for if you are looking at the plugs on the switch. .....Hope that makes sense.
09-29-2007, 07:45 PM | #6 |
if it was a automatic its gonna be a dual purpose switch, neutral and backup switch, the backup switch conectors are perpendicular to eachother like a greater than sign " < (you get the idea)" the other should be parallel(if i remember right) thats your neutral safety. you only need the dual neutral switch if you are going automatic. otherwise if your doing 3 on tree your gonna need a backup switch only. hope that helped.
09-29-2007, 08:23 PM | #7 |
its a turbo 400
09-29-2007, 10:37 PM | #8 |
I have a turbo 350 and that is how mine is set up
09-30-2007, 10:26 PM | #9 |
Licensed to Thrill!
There ya go. This is a picture of HOW TO bypass one, BTW. Also shows you right where it is. DLB Last edited by Orange; 09-30-2007 at 10:27 PM. |
09-30-2007, 11:21 PM | #10 |
Thanks orange. Mine is bypassed just like that.
09-30-2007, 11:25 PM | #11 |
Mine is set up like that two with a Hurst. I will try to start it in neutral and double check the switch. Thanks for the heads up.
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
