Old 09-29-2007, 07:07 PM   #1
RyanG
RyanG's Avatar
Rattle in engine
Well I just took my truck for a test drive after replacing the carb and now I notice there is a small rattle coming from the engine when I put the pedal on the floor. My alternater belt also squeaks when I step on it. Not sure if that has anything to do with it. Could it be that there are some lifters loose or is it the rods? It sounds like pennies or something in a tin can. the oil pressure is good also. Just thought I would add that in.
RyanG is offline   Reply With Quote
Old 09-29-2007, 07:16 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Rattle in engine
Sounds like you're pinging, aka detonation. What octane fuel are you running and how's the timing?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-29-2007, 07:23 PM   #3
RyanG
RyanG's Avatar
I use the cheapest gas I can find 87 oct. and I still have to check the timing. I hope that is all it is.
