Old 09-29-2007, 07:32 PM   #1
hotrodhomi
hotrodhomi's Avatar
Do you use gaskets on your exhaust manifolds?
Today I removed my Ceramic Coated Hedmans and I am going to replace them with Corvette 2.5” ram horns. My question is, do I need a gasket for the ram horns? I’ve been using copper gaskets for my Hedmans and I haven’t had any problems. The directions say “no gaskets”, but that just one mans opinion. I want to know if that is the best method.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 09-29-2007, 07:38 PM   #2
corn
Re: Do you use gaskets on your exhaust manifolds?
Either way is fine with manifolds. Cant hurt, but I dont use them...
corn is offline   Reply With Quote
Old 09-29-2007, 07:39 PM   #3
berencam
berencam's Avatar
i dont really see a problem with using a gasket even if the directions dont want you too...wouldnt hurt anything imo. not a expert tho...
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 09-29-2007, 07:42 PM   #4
hotrodhomi
hotrodhomi's Avatar
Should I use the copper gaskets or is that over kill?
'66 impala ht
Old 09-29-2007, 07:46 PM   #5
BCOWANWHEELS
every engine i,ve dissasembled has exhaust gaskets. and i,am 53 yrs old. they come in every gasket kit i,ve ever bought also.
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-29-2007, 07:46 PM   #6
berencam
berencam's Avatar
i dont see why not.
Old 09-29-2007, 07:48 PM   #7
jaros44sr
jaros44sr's Avatar
Dang, we must be doing the same thing, only 4 hours apart. I'm up to my intermediate mounts, hangers should be here tomorrow
Good question, I was wondering that myself. I'll let you find out, so I can follow
BCOWAN just said to use copper gaskets, he must have been typing at the same time
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-29-2007, 07:51 PM   #8
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
With new manifolds on head port surfaces that are not eroded, a gasketless installation will NEVER leak unless the bolts work loose or break. A gasket WILL eventually burn out. This isn't the case with all engines, but the SBC is almost fail- proof to run without gaskets.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 09-29-2007, 08:20 PM   #9
woodridge
woodridge's Avatar
Small blocks came from the factory without gaskets. I always clean both surfaces and apply a thin coat of aviation permatex. Never had a problem.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 09-29-2007, 08:25 PM   #10
herb101
Used Register
herb101's Avatar
Wow - news to me! I have never seen one without the gaskets. Even my old International has a steel shim plate gasket (like an old head gasket).
Are we all talking about the cylinder head to manifold interface or the manifold to down pipe interface?
Herb
herb101 is offline   Reply With Quote
Old 09-29-2007, 08:28 PM   #11
jerry moss
Born Psycho
jerry moss's Avatar
as long as the manifolds are surfaced flat, you don't use gaskets. i've been at the same muffler shop for over 22 years and we have the manifolds surfaced, clean the head and bolt them up metal to metal. as long as everything is clean and smooth it won't leak--ever.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 09-29-2007, 08:32 PM   #12
Andy4639
Old member
Andy4639's Avatar
Never used them with the ram horns. I clean both sides of the mating surfaces and bolt them up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-29-2007, 08:37 PM   #13
herb101
Used Register
herb101's Avatar
Hmm - I guess the carbon will build up fairly soon and fill in the minor gap between the freshly machined surfaces? I don't think I've ever had a manifold that was actually flat. They all seem to shrink a bit toward the center siamesed ports and twist a bit when they do.
Herb
Old 09-29-2007, 09:28 PM   #14
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Thumbs up Re: Do you use gaskets on your exhaust manifolds?
NO "GASKETS" here and this is a factory resto. on a 283 cu. using ram horns. As far as bolts backing off and causing leaks check out picture #2 and if you look close you will notice the factory "FRENCK LOCKS" installed. This prevents any leaks because of bolts backing off. They ended up being tossed in the garbage can over time. To bad as they do work!
I use Ultra Copper in place of conventional gaskets when installing "HEADERS", this stuff works great. A good set of gaskets cost upwards of $50.00 bucks, this stuff is $11.00 a tube or $6.50 good guy price and there is enough to do two or three sets of headers.
esll.
Oh yea forgot to mention .... Ultra Copper is a Chevy orange in color.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 09-29-2007, 09:29 PM   #15
Truck Hippy
Truck Hippy's Avatar
I have installed manifolds with and with out gaskets and I couldn't tell the difference. Use um if you got um, if not, forget um, lol.
Truck Hippy is offline   Reply With Quote
Old 09-29-2007, 09:42 PM   #16
jake60
1950's small blocks came from the factory with exhaust gaskets but I don't think later small blocks came with them. I "think" if gaskets are used, there is less chance for the bolts to loosen however I don't always use gaskets and have never had any problems.
"Common sense is very uncommon" Rudyard Kipling
jake60 is offline   Reply With Quote
Old 09-30-2007, 08:30 AM   #17
jaros44sr
jaros44sr's Avatar
Thanks ESLL, that was the other question I had. I was going to safety wire bolts, but the locks on bolt heads is a better way to go. I don't know why I didn't remember that
SAFETY FIRST
AS usual, off topic
Jim
Old 09-30-2007, 09:12 AM   #18
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
esll.
When I took mine off, they had those locks on it. I plan on reusing these and eliminating the heat riser stuff. Also, there was no gaskets on mine.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 09-30-2007, 10:23 AM   #19
EAST SIDE LOW LIFE
s/t
Yea they were put there by the factory for a reason .... they work. Good chance your's were never removed until now. Is it the original block? Sounds like it could be! BTW nice looking truck.
esll.
Old 09-30-2007, 10:29 AM   #20
Scott68-93-97
Scott68-93-97's Avatar
Dont run em there is more chance of a leak when using them Ive never had good luck with gaskets on mainfolds, after a month one usually blows out or causes the bolts to loosen up
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 09-30-2007, 10:37 AM   #21
Sport/Truck
Sierra Grande Club
esll.
Thanks, yes all original high nickel block, 4 bolt main. I think the first thing that usually goes is the heat riser; it was a PITA to remove. So I doubt they put them back on.
s/t
Old 09-30-2007, 10:54 AM   #22
Rokcrln
Rokcrln's Avatar
The old guy that I learned from used to use a thin coat of black wheel bearing grease on the manifolds before he bolted them up. He said it will burn right off but leave a slight build up in any small leaks and seal it up right off the bat. If the manifolds are surfaced than it should work out great with out gaskets. Also never use grade 8 bolts for manifolds, use only "Exhaust manifold bolts" besause they are designed with a certain amount of streach to help keep them tight.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 09-30-2007, 11:16 AM   #23
Sport/Truck
Sierra Grande Club
Kevin
LFD Inc.
Good info...I need bolts too any good sources?
s/t
Old 09-30-2007, 11:21 AM   #24
Rokcrln
Rokcrln's Avatar
s/t
Chevy?
Old 09-30-2007, 11:45 AM   #25
EAST SIDE LOW LIFE
Another area that one should exersise extra care in is when you install your exhaust. Use brass nuts to secure exhaust studs that way it will be highly unlikely that you will break a stud or worse yet crack your manifold if you have a repair to make like replacing a donut ect. Notice that the brass nut is also longer then regular nuts. These can be perchased through any Corvette supplier along with a complete bolt kit if your favorite Truck parts supplier does not carry them.
esll.
