Old 09-29-2007, 07:41 PM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Zz4 Is Running!!!
I just about jumped out of the seat. The ZZ4 cranked up on the 2nd crank!!
Sitting in the seat feels like sitting in drag car! It shakes, rumbles, rough idle and smokey!!! The plugs burned up the oil used to turn the motor over. The ZZ4 cranks up quickly and scrippy!!
Video coming soon!! I need someone to hold the camera!!
THANKS TO EVERYONE WHO HAS HELPED ME THROUGH THIS PROJECT!! You can't believe the smile on my face to hear the ZZ4 run. I had neighbors come out and look!!
A little tidy work to check for leaks, loose bolts, tie wrap some wiring and electric fan check are needed. I can't wait to put my foot in it!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 09-29-2007, 09:06 PM   #2
slugish
Slugish
Wink Re: Zz4 Is Running!!!
Congrats on your project . nOT FAMILIAR WITH ZZ4 . iS THAT A CRATE ENGINE .WOULD BE INTERESTED ON ENGINE SPECS ESPECIALL Y DURATION OF CAM .
slugish is offline   Reply With Quote
Old 09-30-2007, 08:23 AM   #3
gchemist
gchemist's Avatar
Block Part Number: 10105123
Block Type: Cast iron with 4-bolt main caps
Bore x stroke (in): 4.00 x 3.48
Camshaft duration (@.050 in): 208 degree intake / 221 degree exhaust
Camshaft lift (in): .474 intake / .510 exhaust
Camshaft Part Number: 10185071
Camshaft type: Steel hydraulic roller
Compression ratio: 10:1
Connecting Rod Part Number: 10108688
Connecting rods Type: Powdered metal steel
Crankshaft Part Number: 12556307
Crankshaft Type: Forged steel
Cylinder head Part Number: 12556463 (angle plugs, Vette head)
Cylinder head Type: Aluminum; 58cc chambers
Displacement (cu in): 350
Engine Name: ZZ4 350:
Engine type: Chevy small-block V-8
Ignition timing: 10 degree BTDC @ 800 rpm 32 degree total @ 4000 rpm with vacuum advance disconnected
Maximum rpm: 5800
NOTE: Distributor with melonized steel gear MUST be used with long blocks
partial engines with steel camshafts, or engine damage will occur.
Piston part Number: 10159436
Pistons Type: High-silicon aluminum with offset pins
Recommended fuel: 92 octane
Rocker arm ratio: 1.5:1
Rocker arms Part Number: 10089648
Rocker arms Type: Stamped steel
Valve size (in): 1.94 intake / 1.50 exhaust
Old 09-30-2007, 02:46 PM   #4
knightlife
Dark Heart Motorsports
knightlife's Avatar
hella grats brotha...glad to hear you got her goin again.
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 10-01-2007, 09:29 PM   #5
HAVA79
Master Blaster
HAVA79's Avatar
congrats!!! you will be even happier when she is rollin........Sorry I didn't get back with ya about your questions, I have been really busy out here now that the weather has cooled down a bit. Let me know if you have any others questions I might be able to help with....jesse
HAVA79 is offline   Reply With Quote
Old 10-01-2007, 11:27 PM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Congrats, G.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-01-2007, 11:41 PM   #7
gchemist
gchemist's Avatar
I need to work on cleaning up a few items. The next step is fix the alternator. Right now the ZZ4 will is running off battery power. The serpentine belt system has a CS130. I plan to use an LED light to tell me when it's charging.
Old 10-02-2007, 09:07 AM   #8
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: Zz4 Is Running!!!
So does this mean your not MR. 305 Any more
Congrats G! Your gonna like it my buddy and i put one in a '55 Belair and that thing was a kick in the ass when ya opened it up
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 10-02-2007, 01:12 PM   #9
68Stepbed
68Stepbed's Avatar
Sweet! Congrats, man. Can't wait to see the video. If I wasn't so far awy I would come hold the camera.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-02-2007, 03:39 PM   #10
pcmcobra
pcmcobra's Avatar
i got a cs130 off my serp setup in for sale section...
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 10-02-2007, 07:09 PM   #11
gchemist
gchemist's Avatar
[QUOTE=87 STEPPER;2384769]So does this mean your not MR. 305 Any more [QUOTE]
Officially yes. However until someone else can get a 305 into the 16's-15's I can honorarly hold the title to the badest stock 305.
The little 305 could spank a stock 350 like spanking the neighbors milk man's kid....
Now much can I get out of the ZZ4? I don't know but you know I'm going to try. I have a 750 carb ready to bolt on. The 650 is probably enough, but the RPM Air gap intake should handle it. I know the tires won't.
Old 10-03-2007, 09:49 AM   #12
Ric83
Ric83's Avatar
Awesome G! Good to hear. If you need someone to hold the camera, you let me know. I would love to hear it in person.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 10-03-2007, 09:22 PM   #13
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
I have no idea what "scrippy" means, but I know you've been working on getting this in and going for awhile now. Congratulations!
On a side note, your geocities site was one of the first few I found when I got my truck like 6 years ago. I've read it front to back a few times, pausing for a day to let you come back down within the bandwidth limit. I'm glad you put up that site, dude. It's been very motivational over the years.
-- Will
killthewabbit is offline   Reply With Quote
Old 10-03-2007, 10:01 PM   #14
boatpuller
boatpuller's Avatar
cool............gonna drop one myself someday.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 10-04-2007, 09:07 AM   #15
gchemist
gchemist's Avatar
Thanks fellas. I want to host an Austin gathering once it's road worthy again. The ZZ4 starts easier than my FI Jimmy. The ZZ4 starts with the slightest starter bump. I'm still working on the videos. I need to fix the oil pressure and tach guages. The digital gauges are not working. I need them to work before the ZZ4 can run for more than a few minutes.
