quadrajet intake manifold
Is the stock manifold the best one for the quadrajet or do aftermarket ones work the same or better? thanks
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
![]() Join Date: Nov 2006
Re: quadrajet intake manifold
stock is best for all around use and even up to 350 hp
I BELIEVE IN JOHN 3:16 |
I have an edelbrok intake and just removed the q-jet from mine. I think it should work with an aftermarket one. I m not 100% sure though.
20' Daredevil (Ret)
![]() Join Date: May 2003
When my stock cast iron intake cracked, I replaced it with an Edelbrock 2101. No noticable difference...
Zappaphile!
has to do more with how you tune the carb's and which you are better at tuning personally. Some people are better with Holleys, some are better with the quadrajets.
I tend to think just with how long the quadrajet lived in the GM corp, there must be some good things about it =). Once you get the hang of them, they can be fun. My only advice would be electric choke, no matter what you end up going with..
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
I had a stock iron on my and replaced it with a Edelbrock 2101. Worked just fine with my qjet.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Sierra Grande Club
I've got a Edelbrock performer air gap 2601. it works with square & spread bores.
http://store.summitracing.com/partde...1&autoview=sku s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
