Old 09-29-2007, 10:22 PM   #1
72freak
Rottenwood Garage Member
72freak's Avatar
Tranny/transfer case question on the 3 speed Blazer
While the 1968 dually project is off to paint and body, I am going to start on the 1972 Blazer. Im sure this is covered in here somewhere but I am going to ask it anyway.
Its currently a 3 speed that "Billy Bob" converted to a floor shifter. I want to convert it to an automatic.
I know i will need a different bell housing but can I use the same transfer case????
What do I do?
I have also given thought to going with a 4 or 5 speed......what can I use?
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 09-30-2007, 06:52 AM   #2
Blazer1970
Blazer1970's Avatar
Re: Tranny/transfer case question on the 3 speed Blazer
Chances are that you have a Dana 20 t-case now with the three speed. That case will not work with an automatic. Your best bet would be to find a TH350/NP205 combo with the adapter. Actually better yet and often cheaper would be to find an entire '70 - '72 truck with the tranny that you want and start swapping parts. That way you have the steering column, crossmember and a hundred other parts that you will need for the swap.
Blazer1970 is offline   Reply With Quote
Old 09-30-2007, 11:14 AM   #3
Classic Bowties
Always on the hunt...
x 2 the blazer will have a Dana 20 transfer case if original, unless somthing has been swapped in at some point. There is no way to use the dana t-case with any automatic tranny. You need to find a complete TH350/NP205 with the adapter, as Blazer1970 stated above it would be best to find a donor rig with the combo you want, that way you get all needed parts in one shot. Another thing to remember is that you will need the 205 x-member setting under the adapter on the 205 combo, or you will need to figure out a way to space your Dana20 x-member down about an inch or so, otherwise the 205 combo will hit the floor pan. The 205 shifter also comes through the trans hump cover in a different spot than the Dana 20, so remember to try and get the auto/205 hump cover from the donor truck or you can always cut a new hole and weld a patch to your original hump cover. Cb
As a side note: I just converted a very clean & original one owner 71 K/5 with 87K original miles from the Saginaw/Dana20 combo to a Th400/Np205 so I have all the just removed oe manual parts (stored inside heated shop) available if anyone is interested in putting their K/5 back to original with this type setup. I have the trans & transfer still bolted together including case shifter and mounting parts, the bellhousing, flywheel/pressure plate/release fork, the manual pedal set, clutch linkage, a super nice & tight 3 on the tree column, both shift links and both front & rear blazer drivelines, to be sold as a complete package only. All parts in great working condition and were only removed for the reason of owner getting tired of shifting a manual, I can take some pics if anyone is interested. Lmk...
Classic Bowties is offline   Reply With Quote
Old 09-30-2007, 04:55 PM   #4
meathead95
computer illiterate
meathead95's Avatar
i have a 72 swb 3spd with an np205 combo i bought from the origional owner so they where available
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 09-30-2007, 05:04 PM   #5
Blazer1970
Blazer1970's Avatar
In a pickup truck, yes. A Blazer came with a Dana 20 behind the three speed.
Old 10-01-2007, 05:28 PM   #6
meathead95
computer illiterate
meathead95's Avatar
gm used many applications. how do you know for sure a np205 didnt come in the blazer behind a 3spd?
72 2wd blazer
72 swb 4x4
Old 10-03-2007, 01:26 PM   #7
I`m pretty sure the Blazers used the Dana20,where the Suburbans and pickups used NP205s.
Old 10-03-2007, 01:38 PM   #8
fun in dirt
fun in dirt's Avatar
I see that Classic Bowties said "The 205 shifter also comes through the trans hump cover in a different spot than the Dana 20..."
So that got me to thinking... I have always thought my Blazer had a 205. However, I've noticed that my transfer shifter is on the driver's side of the the manual stick. While alot of other trucks I see, have it coming out on the pass side of the hump. (My blazer originally had a 3 on the tree, but a PO converted it to 4 in the floor - granny low +3)
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 10-03-2007, 06:02 PM   #9
Blazer1970
Blazer1970's Avatar
The early 205s ('69 and '70?) had a shifter handle that had a 90 degree bend over the adapter so that it came out on the driver's side of the tranny shifter. The later ones had a straight shifter that comes up to the passenger side of the tranny shifter.
