Old 09-29-2007, 10:47 PM   #1
highlow
newbie first ? which axle pics added
Hey guys I'm new here and just have to say WOW this is a cool place. I am hoping to get started on my 47 5 window soon but for now it is collecting parts, I have my tci weld in front crossmember and air ride triangulated four link for the rear so far, but I need to get a rear end for it. What do you guys suggest the 9 inch or the camaro 10 bolt? Just so you know the plans for the truck are to bag it and make it lay flat on the ground.
highlow is offline   Reply With Quote
Old 09-29-2007, 11:16 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: newbie first ? which axle
Welcome to the board. You will get lots of help and advise from the folks.
We also like pictures of projects.
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 09-30-2007, 07:41 AM   #3
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 09-30-2007, 01:32 PM   #4
56chevy1300
56chevy1300's Avatar
I think both axles will work fine...I have a 10 bolt from a 2nd gen Camaro
56chevy1300 is offline   Reply With Quote
Old 09-30-2007, 03:32 PM   #5
Kid
Kid's Avatar
You will have an easier time welding your triangulated 4 link to the 9 inch because of the 1 piece rear housing, also cheaper/ easier to change gears in the 9" because it can be done on the bench. For the above reasons, I suggest the 9"
Kid is offline   Reply With Quote
Old 09-30-2007, 04:04 PM   #6
Jerry Jones
Happy Camper
Jerry Jones's Avatar
Pics... we need pics
Welcome aboard from California
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 10-01-2007, 02:39 PM   #7
mcarrel
Welcome hope you enjoy your build. Either should work fine if you can find a deal you may consider the Ford 8.8 rear axle it is pretty tough unless you are pushing mega HP. There were a bunch of the Ford 8.8 that came with disk brakes. This is what I used on my project found the rear axle locally for $56. You can check out some photos of the rear axle here. http://www.tagworld.com/azmark
mcarrel is offline   Reply With Quote
Old 10-01-2007, 03:35 PM   #8
mylow53
mylow53's Avatar
i'm partial to the ford mainly cause nascar uses a version of them... also my 4 link just clears....
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 10-01-2007, 11:37 PM   #9
highlow
thanks for all the info guys I will get some pics up as soon as I can.....mcarrel please tell me where I can get that rear end with the discs already on it that would work for me.
Old 10-02-2007, 12:57 AM   #10
lotussutol
most junk yards will have ford 8.8 rears with discs already on them. most are limited slip and decent gears too.
Lotus
Current Rides/Projects
1955.5 Chevy shortbed truck
1952 Chevy Coupe Deluxe car
lotussutol is offline   Reply With Quote
Old 10-02-2007, 06:02 PM   #11
mcarrel
Highlow my rear axle came out of a 1986 T-Bird turbo coupe 3:73 gear limited slip it is 59 1/2 inches wide almost exactly the same width as the original. One problem with these is they have 4 bolt lugs bought new hardened axles and adapter plates so I could use common Ford Mustang disk brake parts. Mustang calipers etc are dime a dozen compared to the turbo coupe ones. The place for these parts was http://www.northracecars.com/index.html ask for Richard he is a great guy he helped me thru all of this.
Let me know if you need more info.
Old 10-04-2007, 12:44 AM   #12
highlow
Okay here are the pics of my truck.....need to move it out my gargage and over to the shop so I can start getting some work done
Old 10-04-2007, 12:48 AM   #13
highlow
Re: newbie first ? which axle pics added
some more
Old 10-04-2007, 12:56 AM   #14
highlow
another one
Old 10-04-2007, 01:49 AM   #15
stevehsd
stevehsd's Avatar
I've got a chevy 10 bolt w/ disks, works great, nice width, chevy bolt pattern, from a 3rd gen camaro, '84 I think. But Ford 9 in looks like the sh@t, like a 350 motor, or a MII sus, or a 700r4. I went with the 10 bolt because I had it, but a
Ford 9 in is what I wish I had.
51 3100 build thread http://67-72chevytrucks.com/vboard/s...light=stevehsd
77 FLH
stevehsd is offline   Reply With Quote
Old 10-04-2007, 01:55 AM   #16
highlow
hey stevehsd, my truck came from Hollister. Have alot of family there and we go quite often
Old 10-04-2007, 11:50 AM   #17
Daniel U
Daniel U's Avatar
My entire power train is from my '84 Z/28 that state Farm totlaled. It will even be TPI when I'm done! My 10 bolt will be plenty stong as I never plan to tow. It has disc brakes 'cause the PO of the Z/28 dropped an '87 rear in it with 3:73 and an Auburn posi.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 10-18-2007, 12:30 AM   #18
highlow
hey is the 59 1/2" measurement for the rear axle outside of drum or inside of backing plates? what would be the best donor vehicle for a perfect fit 9"? I got a guy wanting to do a trade and he is willing to find me the right 9" if I give him some idea what to look for. any help would be great guys
Old 10-18-2007, 03:26 PM   #19
solidaxel
solidaxel's Avatar
You might try 69 to 70 Mustangs
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-19-2007, 12:11 PM   #20
Bills_49
Broke Club =(
who did you go with on the 4-link?
Bills_49 is offline   Reply With Quote
Old 10-19-2007, 07:35 PM   #21
Kabwe
Certified Car Nut
Kabwe's Avatar
I have a 1973 Chevy 8.5 posi 10 bolt with 3:42 gears. A 72-81 gm 8.5 rearend will handle good power just fine. The thing about 9 inch that is desirable is the pumpkin drops out as a unit and the axel are not retained with c-clips (the ford 8.8 does have c-clips). I also think that the Ford 8.8 are lower priced the Chevy big 10 bolt. I brought mine on craigslist for 200 bucks. I believe other the the Grand Nationals Chevy did not use the 8.5 after 82, they used 7.5 rearends.
Kabwe is offline   Reply With Quote
