Old 09-29-2007, 10:59 PM   #1
67Mach1
67Mach1's Avatar
How To Identify a Posi Rear end?
I think one of the trucks I picked up this weekend has a Posi rear end. Mainly because the guy said it did. But , secondarily because when I turned one wheel the other wheel did not turn in the opposite direction.
This was done with both rear wheels off the ground BTW.
Now since the other wheel did not turn in the oposite direction, in fact did not turn at all does that prove or disprove anything?
Thanks,
OH it is a 12 bolt and had the following number on it 06818 stamped or molded into the center section, no tag avaliable.
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 09-29-2007, 11:33 PM   #2
sdkid
Re: How To Identify a Posi Rear end?
If you can still read the gove box label, that may tell you. Jack one side up. The other tire is on the ground. Try to turn the wheel. A axle with posi will not turn.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 09-29-2007, 11:47 PM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Lemme know what you decide to do with those trucks bro !!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 09-30-2007, 12:13 AM   #4
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
As said before. The easiest way to tell is to pull the cover.
If its on the options sheet, there is no telling if a previous owner swaped it out.
Jason
jay_shy is offline   Reply With Quote
Old 09-30-2007, 12:37 AM   #5
corn
I agree with Jason. The SPID will tell you if the truck came with a posi but it cant tell you if its still in the truck...
corn is offline   Reply With Quote
Old 09-30-2007, 01:03 AM   #6
Frizzle Fry
Frizzle Fry's Avatar
Neither will an open diff if the driveshaft is still there and it's in gear or park... Just be sure it's either in neutral or the DS is removed
Frizzle Fry is offline   Reply With Quote
Old 09-30-2007, 07:49 AM   #7
Remove diff cover and observe the lack of spider gears/open carrier in center section,if it`s posi.
Old 09-30-2007, 08:43 AM   #8
67Mach1
67Mach1's Avatar
Thanks everyone for the help. THe rear end did not have the DS installed but we did it with both tires off the ground. Once I can get back out there I will either open the rear up or try to do it with one tire on the ground and see what happens.
Spraybomb: It was all I could do yesterday to get them moved and over to the farm. Which is about 1.5 hours away from where I live. Until I go over everything and figure out what I'll need, no promises on what will be up for sale.
I can tell you this most body panels are rusted out in at least one place. its the extra parts and the frames that are worth the purchase price.
is for sale
Old 09-30-2007, 10:59 AM   #9
billsbowtie
billsbowtie's Avatar
sometimes they still have a tag like this on them.
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 09-30-2007, 11:01 AM   #10
billsbowtie
hears what it looks like with cover off.
Old 09-30-2007, 06:14 PM   #11
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Look for vent tube if it is a posi it will have one. Posi lube warning tag is on the diff. plug.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 09-30-2007, 07:19 PM   #12
billsbowtie
east side do the non pois. rears have a vent tube also? my project truck has a vent tube and i am almost sure its not pois. yet.
Old 09-30-2007, 08:13 PM   #13
EAST SIDE LOW LIFE
They have a breather tube with a cap on the top. I don't have a picture or I would post it. This can be found on google. You can jack up your frame and spin one tire if posi both will turn.
esll.
Old 10-01-2007, 08:28 PM   #14
68caliRat
Need a bigger hammer..
Vent on a posi? I have a Dana 60 with posi(stock) and there's no vent tube. I'm not doubting that they may have had them on some, but mine didn't.
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
Old 10-04-2007, 12:56 PM   #15
EAST SIDE LOW LIFE
Here is a picture of a vent tube on a 1960 Vette rear end. It's the metal tube that is attached to the diff. housing and looks like it's going no where.
esll.
Tha Dana rear end I cannot say what the deal is there. But if it is factory that way that does not mean that is the case for all posi's.
Old 10-04-2007, 01:58 PM   #16
Scott68-93-97
Scott68-93-97's Avatar
Best way to tell is hold your foot to the floor and get out and view the marks or pull the cover, the wheel spinning deal doesn't always work, excpecially with a gov lock or tosion lockers, both have a similar locking mechanisms that sense a difference in rotation and lock up, like on my 97 its open if you turn the wheel very slow opposite side turns opposite but when you quickly turn the one side it locks in and both turn the same direction and it stays locked until theres more force on one side like when you go around a turn, it will also lock in if you apply power. The gov locks you will know if you have one you can actually here them lock up there common on 4x4's
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 10-04-2007, 02:27 PM   #17
Classic Bowties
Always on the hunt...
EAST SIDE: I agree on the Lube Tag, and will add that most of the time they are missing anyway(like the last 3 posi's I pulled), so if the tag is seen/found chances are very good that you have a posi and even if the tag is not present it is still worth the time and effort taken to remove the cover to know/verify what you have for sure, you just never know what's in there after 35 plus years of service
As far as the vent tube (as per your added pic) being a indicator of a positraction and/or only being on posi axles, I wolud have to disagree. I currently have a 67, two 68's & early 70 all with narrow housing non-posi/open 6 lug 1/2 ton rear's and they all have the vent tube attached to the frame x-member or the pass. frame rail. I also have a 71 and two 72's all with wide housing non-posi/open 5 lug 1/2 ton rear's and they all have the vent tube secured above on the frame x-member. Cb
Classic Bowties is offline   Reply With Quote
Old 10-04-2007, 04:12 PM   #18
Frizzle Fry
My open diff rear has a vent tube.
Old 10-04-2007, 04:54 PM   #19
EAST SIDE LOW LIFE
Most times I turn one wheel after jacking the vehicle up and blocking the other wheel and this usually is a good indicator. I guess it doesn't work in all cases as one member has stated. Most rear ends are vented. I thought non posi rear ends used a breather vent and posi's used a tube. I have a 50, 60, 70 all posi rear ends with vent tubes. All three of them the covers have been pulled and were posi's. I guess to be sure one must pull the cover!
esll.
Picture of breather vent that has pop up and no tube. I always thought these were used as vents on non posi's.
Old 10-04-2007, 06:02 PM   #20
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
May have to try that one up / one down / neutral / spinthingy test
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
