Old 09-30-2007, 01:42 AM   #1
jlaird
jlaird's Avatar
sandblast and paint prep
I'm getting ready to bring my frame to the blasters. My question is should I leave all the crossmembers bolted in (main front crossmember, tranny crossmember, and trailing arm crossmember(no longer riveted)) or should I unbolt them and have them blasted and painted separately and then assemble?
jlaird is offline   Reply With Quote
Old 09-30-2007, 03:00 AM   #2
earl87gta
earl87gta's Avatar
Re: sandblast and paint prep
I would pull them apart and prime and paint individually then bolt it all together and paint last coat.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-30-2007, 09:33 AM   #3
ChevyDude
Whatever you do, get a written quote when you drop the frame off. I just had a nightmare with the blaster up charging by nearly 233%.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 09-30-2007, 10:26 AM   #4
jlaird
jlaird's Avatar
yea, I was following that thread. What a nightmare!
Old 09-30-2007, 04:18 PM   #5
jlaird
jlaird's Avatar
any other opinions?
Old 09-30-2007, 05:06 PM   #6
jasonb72
PorterBuilt Man Crush
Originally Posted by jlaird View Post
any other opinions?
I would powder them, it is more durable and cheaper unless you do it your self. Either way, I would recommend taking them apart. I had mine powdered, and did not take them apart and had some build up in the crevices that I did not like.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 09-30-2007, 07:07 PM   #7
earl87gta
earl87gta's Avatar
On the frame if you pain instead of powder i would apint it the last coat when its back to gether so all the bolts are painted up and it acts like a seal where every thing comes togeterto help from getting water and stuff in the cracks.
Earl
