Old 09-30-2007, 02:33 PM   #1
loader820
lifter
need to chage the lifter an push rod,an spring will it have something to do with the compresion i hav cam it a s/b 350 do not pick up speed number 1 lifter in lose can not tighten it nomore
loader820 is offline   Reply With Quote
Old 09-30-2007, 05:57 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: lifter
From what I gather you have a flat camshaft lobe. If that's the case then the camshaft will need to be replaced. Or it could be the rocker arm stud has pulled out of the cylinder head.
Is the engine stock or have there been modifications done to it?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-30-2007, 06:46 PM   #3
loader820
Re: lifter
yes there been modifications done to it
Old 09-30-2007, 07:12 PM   #4
MylilBowTie
Right turn Clyde
Re: lifter
It would make it much easier to diagnose if we know what those are. What all has been modified? Need to all the specifics on the engine. That will give everyone a better idea of what happened or is going on.
