Old 09-30-2007, 02:57 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Vin #on frame... where are they..
Can anyone tell me where the vin # is stamped on these early frames. My truck had already been clipped when I bought and just want to make sure the vin matches the title.. Thanks Luke..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-30-2007, 03:36 PM   #2
lotussutol
Re: Vin #on frame... where are they..
my 55 has a vin tag on the driver side window pillar. I am not aware of any numbers stamped into the frame.
I had a 52 chevy truck too but it had a california highway patrol vin tag on the driver side below the door striker.
Lotus
Current Rides/Projects
1955.5 Chevy shortbed truck
1952 Chevy Coupe Deluxe car
lotussutol is offline   Reply With Quote
Old 09-30-2007, 03:52 PM   #3
prostreeter58
prostreeter58's Avatar
The numbers on my '59 are on the drivers side just forward of the front axle and about mid way back on the same side...........hope this helps.
prostreeter58 is offline   Reply With Quote
Old 10-01-2007, 11:32 AM   #4
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i found some after wire-wheeling my frame on the top side driver's side rail, underneath where the cab goes
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
