Wet blasting. Freakin amazing
I saw a sand blasting attachment for a pressure washer on here and I decided to give it a shot. I saw several on the internet at various sites anywhere from 120 to 200 dollars. I ended up going to Northen tool and bought mine for $62.99. This thing is freakin amazing. I was out playing with it for about an hour and blasted about half of the frame. I also had a fender that I was not going to use and thought I would see what it did to sheet metal. I have seen several posts on here saying not to sandblast sheet metal because it would warp, but I did about half of the fender in about 20 minutes and everything looks good. NO WARPING. I am just using regular sand. Similar to play sand. The only drawback I see so far is that it uses a TON of sand. I went through about 100-120 lbs in two hours. Luckily for me I work in the oil field and we usually have about 10-20 semi trailers full of sand in our yard at all times. Here is my only question. Within an hour of blasting my frame I can see some orange. I don't really have enough free time to do the whole frame at once and prime it at the same time. What do I need to do about this. The whole rust removal and paint preparation is not my specialty. Is this orange anything to worry about or will I be able to get a primer that will kill it?
Re: Wet blasting. Freakin amazing
If you spray Metal Prep from POR on it it should not rust anymore, according to POR. I think I remember seeing that .
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson Last edited by Husker; 09-30-2007 at 06:43 PM. |
r u saying to just spray the metal prep over the orange tint that is coming up on the frame? My chasis is still a roller and I need to take it completely apart so I can do one piece at a time. That should help with the time frame. Is the metal prep in a spray can?
Metal prep is a POR product and it is a spray on metal etch before you paint. I could be wrong on it keep it from rusting further my label is about washed off.
Be careful with some primers they soak up moisture and will rust through. Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
