09-30-2007, 07:53 PM | #1 |
ran out of money
power brake booster size?
hello everyone, I was just wondering what the stock size booster was for a 71 with power brakes? was it an 11 inch?
any insight would be great! Thanks! 71rat
Modify everything, leave nothing alone!~ |
09-30-2007, 08:06 PM | #2 |
Re: power brake booster size?
I am at school at the moment but I found the booster on napa's website and the diameter it mentions is 10 3/4"
Here is the link: http://www.napaonline.com/masterpage...aster+Cylinder I hope this helps |
09-30-2007, 08:13 PM | #3 |
ran out of money
betonj97: thank you i forgot to check napaonline.....
71rat
09-30-2007, 08:48 PM | #4 |
I do not have the booster. Will there be mounting braket or placement to bolt to already on my truck. 71 also
10-02-2007, 11:06 AM | #5 |
You would have to pick up a bracket from a salvage yard and the mounting holes might not be there if you only have a master cylinder on there. no to sure though. I believe the best or only bracket to go with is up to a 72'.
Hope this helps somewhat..... |
10-02-2007, 11:28 AM | #6 |
Yes, thanks, I suppose it's easy enough to look for holes where the braket would mount. If not it would be a trick to get exact for everything to line up?
10-02-2007, 08:24 PM | #7 |
I am a Referee of life.
You will also need the rod to the pedal.I can't remember the exact issue but there is a difference.Maybe someone will add info.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
