09-30-2007, 08:35 PM | #1 |
what tools for lowering?
i just ordered a 3/5 drop from jcwhitney. its a western chassis with front drop springs and a flip kit in the rear. no c notch. what tools will i need to do this? i still have probably two weeks before it gets here. i hope tires wont rub. right now i have 31.50's on there. will have to do till i can save up some more dough.
any ideas what i can do about that tailpipe hanging there? i have the original i6 in there and dont wanna do anything drastic but it sure looks funky hanging there. i wanna replace the motor on down the road but that will probably be the last thing on my list. the last truck i had i lost interest when i had the motor out so long and ended up selling at a huge lost. |
09-30-2007, 08:57 PM | #2 |
350+dual flows= fun :)
Re: what tools for lowering?
tool:
anything you think you might need...you will need kit: got a link to the kit you got? exhaust: cut it off before the rear axle
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!! SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!! |
09-30-2007, 09:05 PM | #3 |
standard socket set.
Hammer for "pursuading" ball joints/spindles loose, flathead screwdriver, needlenose pliers.(for cotter pins) Grinder for taking rivets out in rear. Balljoint separator, could use that for tie rods also... I did not have to cut my exhaust....
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native Last edited by pcmcobra; 09-30-2007 at 10:22 PM. |
09-30-2007, 09:26 PM | #4 |
10-01-2007, 09:36 AM | #5 |
You will also need a decent drill motor and a 3/8 drill bit to install the aftermarket bump stops on the rear. A torch may be needed to persuade the rear shackle/spring bolts to move. Those were a pain on both flip kit installs I have done.
You should be okay on the tires. I have 235/70/15 on the front and 31/10.5/15 on the rear of my 3/5 dropped truck. I had 255/70/15 on the rear, but after the drop, the rear sat lower than the front. The taller tires on the rear fixed that problem. |
10-01-2007, 03:37 PM | #6 |
Dark Heart Motorsports
BFH... (big F'n Hammer)....
works for everything
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
10-01-2007, 07:20 PM | #7 |
If your only doing springs in the front shouldn't need a ball joint separator just remove the brake caliper, unbolt the shock and remove the upper a arm from the frame (your going to need a wheel alignment anyway), have the truck on jack stands with the trolley jack under the lower a arm. Slowly lower away. I find its the fastest way to change front springs
1979 C20 pickup 454 big block turbo 400, 4.56 gears |
10-02-2007, 11:31 PM | #8 |
Nice truck, mine has a I6 too. I don't know if anyone said anything about the bed, It pretty much has to come off, wich is fairly easy, 8 bolts and a guy on each corner. also have to undo the gas tank filler from the body and the wiring plug to the taillights. as for the rivets I couldn't get to all of them with a grinder, what work great for me was a good cold chisel and about a 2-3 pound hammer. good luck
10-03-2007, 04:03 PM | #9 |
u mean i cant leave the bed on?
10-03-2007, 04:08 PM | #10 |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
10-03-2007, 04:18 PM | #11 |
Cruzzzn' Vet
10-03-2007, 04:23 PM | #12 |
or just get a chunky woman to sit on the hood, and 2 to pose provocatively in the bed --- the height of the truck will come down, and all it will cost is a couple of bags of peanut butter cups ---
and will still be as practical as a lot of airbagged trucks i have seen |
10-03-2007, 08:22 PM | #13 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
10-03-2007, 09:15 PM | #14 | |
Insert Witty Text Here
Sorry Jeff. I swear I will finish up that article for you.
Slonaker Quote:
10-03-2007, 09:25 PM | #15 | |
yeller
No hurry, I haven't done much site work in a while, been busy myself too.
