Old 09-30-2007, 08:40 PM   #1
67Step
67Step's Avatar
Arrow Lower Ball Joint Installation
Just a quick question for you guys. When replacing the lower ball joint do these need to be put in with a press? I tried putting mine in and they wont pull up so figured I would try pressing them in. Any other suggestions?
1967 Chevy Shortbed, 454 CI, 700R4, currently work in progress. Check out the build up at http://www.cardomain.com/ride/2933497/1.
http://67-72chevytrucks.com/vboard/s...d.php?t=264458
1956 Chevy 3100 4x4 Stepside Truck. Sitting on Tahoe frame with LS motor.
67Step is offline   Reply With Quote
Old 09-30-2007, 08:45 PM   #2
john
member #16
john's Avatar
Re: Lower Ball Joint Installation
Yes a press would be the right tool.
john is offline   Reply With Quote
Old 09-30-2007, 09:37 PM   #3
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Wink Re: Lower Ball Joint Installation
if you don't have a press here is another way to do it
#1 put the new ball joint's in your freezer for a day
#2 heat the lower A-arm's slightly with just a normal propane torch (IT'S NOT HOT ENOUGH TO HURT ANYTHING)
#3 find a peice of thick pipe or ? just something that will fit over the ball joint and rest on the metal lip of the A-arm
#4 sit the ball joint in the A-arm fresh out of the frezzer will the A-arm still hot and with the ball joint resting on a big socket or something hit the assemblie from the top thus driving the A-arm down onto the ball joint
hit it till it bottom's good and let it all warm and cool ,,,,,
someone told me that would work !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 09-30-2007, 09:41 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Or you could just rent the ball joint press from the auto parts store.Also NT or HF will hAVE ONE FOR AROUND $20.00
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-30-2007, 10:02 PM   #5
ERASER5
ERASER5's Avatar
If the A-arm is still attached to the truck, ball joint press.
If the A-arm is removed from the truck, use any press you can find. A swing press (hammer) will work, but it can be a LOT of work.
If possible, cool the joint and heat the A-arm as 19673onthe tree said.
I like the ball joint press my self.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-30-2007, 10:21 PM   #6
VDOG
Grand PooBaa Member
VDOG's Avatar
I took mine out and had the local autoparts store press them in for me at $10.00 each. The top ones I just bolted in after removing the rivets.
VDOG is offline   Reply With Quote
Old 10-01-2007, 09:57 PM   #7
67Step
67Step's Avatar
I took the lower A arms down to my local parts store. They were kind enough to let me use their press in the back. I installed the lower ball joints in both A arms in about 10 minutes. I now have the front end together with new tie rod ends and all. We put the 454 and 700R4 in the newly painted frame today. It is slowly coming along. The hedman headers worked out really well. We had to cut the frame a little bit on the passenger side.
Old 10-02-2007, 12:11 PM   #8
VDOG
Grand PooBaa Member
VDOG's Avatar
Did you remember to add grease to the new tie rods and ball joints?
My local auto shop told me they did, they only did one.
