09-30-2007, 09:26 PM | #1 |
67 Chevy Stepside
what all i need to put a 73 grill in a 79 truck
what all i need to put a 73/74 grill in a 79 truck.. is it just the middle support thing or do i need the 2 sides to
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
09-30-2007, 09:35 PM | #2 |
Re: what all i need to put a 73 grill in a 79 truck
The 73-74 grill is deeper, so yes, you need the middle and side supports.
09-30-2007, 11:18 PM | #3 |
www.73-87chevytrucks.com
You need the complete latch assembly, and the outer grill mounts
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-01-2007, 12:47 PM | #4 |
Here are the pieces you need for the 73-74 grille to work... The last 2 pics show the vertical support with 2 mounting locations and the outer location for mounting.
10-01-2007, 02:03 PM | #5 |
Happy to be here
Chris- Are "all" of the places I have circled mounting tabs? How do the brackets attach to the core support? Do you know if they are different for a 73-74 GMC grill?
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-01-2007 at 02:04 PM. |
10-01-2007, 02:56 PM | #6 |
The 4 in the center are made into the supports, I can verify if you need. This differs from the 75-80 version as the bolt to the large area adjacent to those pieces.
The outers singles bolt onto the support behind the headlight. There are also 2 more in the center of the core support that is specific to the 73-74 grilles. GMC and Chevy are the same.
10-01-2007, 08:40 PM | #7 |
If memory serves me correct, the plastic clips for the grille attach screws are unique to the '73-74 grilles. I found some NOS ones on ebay. The '73-74 grille is my favorite of all the 73-87 styles.
N2Trux: In the areas you circled, the brackets adjacent to the headlights are bolted to the core support, and the ones close to the radiator opening are part of the support structure that comes directly up from the core support mounts. I just looked at my spare '73 core support, and I'm almost certain that the 73-74 core supports are different from the later years Last edited by chevyrestoguy; 10-01-2007 at 08:59 PM. |
10-01-2007, 08:52 PM | #8 |
Happy to be here
OK so I need a set of the outer brackets, and will need to make something for the inner mounts. The core support I am using came from an 80 Blazer which is the style I wanted for the inside hood release.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-01-2007 at 08:55 PM. |
10-02-2007, 10:40 AM | #9 |
Just a follow up, they are made into the core support. There should be 2 bolt holes on the channel that you could put a nutset in to bolt what you need to the core support.
That is correct chevyresto, Attach clips are specific to the 73-74.
10-02-2007, 10:50 PM | #10 |
67 Chevy Stepside
ken i found a extra set of the center and outer today when i was at the jy
10-02-2007, 10:57 PM | #11 |
Happy to be here
Did you pick them up? PM me with details....
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-02-2007 at 10:57 PM. |
10-04-2007, 11:48 AM | #12 |
If he didn't, I can possibley get those off the truck in the picture. I took it last week.
10-05-2007, 11:48 PM | #13 |
67 Chevy Stepside
got them thank ken
10-06-2007, 04:32 AM | #14 |
Hmm...maybe this whole ordeal explains why the previous owner of my 78 installed the 73-74 cheyenne super grill just two screws to the center support. I'm guessing he got the correct center support and had enough of it.
