Old 09-30-2007, 11:31 PM   #1
wildmanaaron
Can you remove power distribution block on firewall?
I am wanting to clean up my engine bay alot and the power junction block (diamond shape thing mounted on firewall) is a big eyesore. I have seen alot of custom 73-87 era Trucks that have a completely smooth firewall or wires hidden that are not using this junction block, so it must be possible. I am not using the factory A/c system so the wire that goes to that won't be used now.
Anybody got any ideas or suggestions on this topic??
wildmanaaron is offline   Reply With Quote
Old 10-01-2007, 03:12 AM   #2
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: Can you remove power distribution block on firewall?
There are a few on here that have made covers over the block. Not quite sure who though. I think Ken (N2TRUX) has made one, you might ask him about it.
xtreme80 is offline   Reply With Quote
Old 10-01-2007, 04:40 AM   #3
moneyeater
moneyeater's Avatar
I rewired my truck completely and placed the junctionblock on the innerfender halfway between the battery and the starter.Iīll make a cover for it and shut all the litte holes in the firewall! It was quiet a task to hide all the wires as much as possible in black wireloom and make everything work correctly but it looks really great and is easily accessible if necissary!
We used old steelflex brakelines and leftover chromed radiatorhoses for single wires and the little hose on the blowermotor.
I think you donīt want to rewire your truck but the junctionblock on the firewall should be easy to relocate somewhere lower in the enginebay!
....and donīt forget to disconnect the battery while working on the electrical system!
Name:  DSC01400 [640x480].JPG
Name:  IMGP0085 [640x480].JPG
Name:  IMGP0008 [640x480].JPG
moneyeater is offline   Reply With Quote
Old 10-01-2007, 08:31 AM   #4
85_SWB
85_SWB's Avatar
Attachment 303510
Attachment 303511
Attachment 303512
Attachment 303513
Attachment 303514
so what look to be heater hoses actually just have wires running through them?
1985 C10 SWB- *Project*
85_SWB is offline   Reply With Quote
Old 10-01-2007, 03:39 PM   #5
knightlife
Dark Heart Motorsports
knightlife's Avatar
as always, moneyeater for the win... brother, your truck is immaculate as always.,.,.leaves the majority in envy
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 10-02-2007, 04:33 AM   #6
moneyeater
moneyeater's Avatar
Thanks for your comment!
.... and the best thing about it is that everything works properly without any leaks and trouble yet! I was a little concerned about that because all the seals and parts were dry for almost 10 years now!
@ 85 SWB: No the heaterhoses are what they supposed to be.Its just the littlt ventinghose on the blowermotor that we dressed up with some leftover to clean the enginebay up and carry on with one theme!
I hope you all like that as much as i do!
Old 10-12-2007, 03:13 PM   #7
wildmanaaron
Looks as if your Truck originally had Air Conditioning. How big of a hole did you have to make to mount the heater box on the firewall. I am about to remove my A/C set-up and go with a non-ac setup.
Old 10-12-2007, 03:22 PM   #8
Malo83
Cruzzzn' Vet
Malo83's Avatar
She's looking Killer moneyeater
Malo83 is offline   Reply With Quote
Old 10-13-2007, 02:44 AM   #9
moneyeater
moneyeater's Avatar
That is right and it was quiet a bit of fabricating as usual on my truck but worked out fine and works well!
These are the holes side by side!
Name:  Heizung14 [640x480].JPG
Name:  Heizung16 [640x480].JPG
Old 10-13-2007, 12:59 PM   #10
wildmanaaron
Thanks for the pictures. Those are exaclt what I wanted to see. Here's my problem. I have a Blazer and the only time the top would stay on it is in the Winter or colder months. So all I really need is a heater.
