Old 10-01-2007, 06:04 AM   #1
cmcolumbus
cmcolumbus's Avatar
helper springs
any body know where I can get helper springs for my 72 with rear coils,
I want to put them on and take them of as needed.
cmcolumbus is offline   Reply With Quote
Old 10-01-2007, 06:23 PM   #2
gotchevys?
gotchevys?'s Avatar
Re: helper springs
Ive got a set I took off my 67
www.fatdaddieshotrods.com
gotchevys? is offline   Reply With Quote
Old 10-02-2007, 11:35 AM   #3
OLDIRON69
Re: helper springs
Lmc
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 10-02-2007, 12:26 PM   #4
Ovidiu
Re: helper springs
Hey, this is a good question. Do those helper springs fit on a swb 68 stepside with rear coils? what if the truck were lowered?
Ovidiu is offline   Reply With Quote
Old 10-02-2007, 02:14 PM   #5
Classic Bowties
Always on the hunt...
Re: helper springs
cmcolumbus: Here is a pic of what you are looking for, start looking at your local area wrecking yards for any 63-72 GM 1/2 or 3/4 ton coil rear truck and just be sure you get all of the pictured parts for your setup. Good luck hunting, Cb
Classic Bowties is offline   Reply With Quote
Old 10-02-2007, 02:35 PM   #6
gotchevys?
gotchevys?'s Avatar
Re: helper springs
Ovidiu,
The springs should technically fit on a SWB truck but you would have to modify the rear bumper brackets and drill some holes. The first picture I attached shows the location of the springs on the frame. The second shows the spring mounting holes after I cut 8" from the frame to shorten it to a 115" wheelbase.
As far as a lowered truck they will not work. If you notice in the first picture, the springs hang a few inches above a rubber bumper attached to the end of the trailing arms. When the truck in loaded the helper springs come into contact with the bumpers. If the truck were lowered the springs would either be very close to the pads or in constant contact with the pads.
Old 10-04-2007, 04:33 AM   #7
cmcolumbus
cmcolumbus's Avatar
Re: helper springs
Thanks guys I will start hunting.
Old 10-04-2007, 09:14 AM   #8
Ovidiu
Re: helper springs
gotchevys? thanks a lot for the info!
Old 10-04-2007, 09:33 AM   #9
bw4sale
bw4sale's Avatar
Re: helper springs
I've got a 68 short step with a set of helper springs that look different than those. They are a stack of 3 or 4 bands that face toward the front of the truck.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
