Mystery problem?
My truck has a mystery problem. You can drive it all day at 40mph or less, but when you get up to 45-50 mph it’s like it runs out of gas and quits. It starts right back up with no problem, so that leads me to believe it’s not an ignition problem. I have put two different fuel pumps on it, and it does the same thing. What do you guys think?
Thanks, Tim |
Re: Mystery problem?
Had the same problem on my 65 drove me nuts, it was a piece of plastic partially blocked in fuel line. I cleaned out it was ok just my thought.
Junior Member
Fuel filter. Try replacing the fuel filter. This is exactly how they act when the fuel filter gets plugged up because only a small amount of fuel can get through. When idling or driving slow it's getting plenty of fuel, but when you go faster it runs out of gas.
_______________________________________ 62 SWB BBW (under construction) 86 Vette Convertible |
As pointed out, some kind of corrosion or blockage in teh fueld line is likely.
You've put in two fuel filters already, not likely two in a row were bad, so that is probably okay. I presume you are talking about in-line filters here. Some carbs also have built in fuel filters, like my Holley. I had sort of an equal-but-opposite problem Sometimes my carbs would leak gas, it came running out on a throttle shaft mostly, just poured if engine (fuel pump) was running. Sometimes it was fine. It turned out there was a spring that holds the element in place in the built-in filter. This spring had borken, and sometimes the end would poke through and prevent the float needle from seating. Found and fixed during a carb rebuild. Anyway, for your problem, if you have asuch a filter it might be clogged. It is easy to overlook since it is "hidden" in the carb body. |
resident wrencher
had the same prob re place all the hoses filters and pump but there was a little pump on my holly that craped out
![]() Join Date: Nov 2006
yeah, more than likely a blocked/clooged line or filter.
Also check the metal lines, especially around the fuel pump because sometimes they will get bent and crimp at the bends, restricting flow. |
The gas tank was cleaned out and sealed. It has all new fuel lines, and new filters. The carb was rebuilt, but it is a crappy carb to begin with. The line going to the carb does have a little too much crimp in it, I'll try that and let you know what happens.
Thanks, Tim |
Hollister, CA.
![]() Join Date: Sep 2006
I would check the float operation and the adjustment of the needle.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Hey get this a buddy of mine said why not try driving that truck once without a gas cap. I said hell it's the same cap its had on it since I got it and I didn't have this problem before, but guess what it worked. I know the tank has to be vented. I guess I need a new vented cap. Crazy!
Still Truckless!
~James ![]() ![]() 2009 Hyundai Sonata<~~Wife's sedanomatic 1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive ![]() ![]() ![]() ![]() |
