Old 10-01-2007, 06:48 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need some help with running lights/taillights..
My side marker lights and taillights seem to have failed any suggestions on where to look. I have checked the fuses and wires and everything is in place. Everything else on the truck works even the reverse lights and brake lights can someone point me in a direction.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-01-2007, 06:51 PM   #2
energiesource
Re: Need some help with running lights/taillights..
did you check all the wiring leading up to it? maybe some of the wires are frayed? the brake lights are the tail lights so i dont know how the brake would work and the tail lights wouldnt but other than that, and the fuses, i got nothing. bulbs maybe?
energiesource is offline   Reply With Quote
Old 10-01-2007, 07:11 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Never mind I guess that if you remove the horn fuse on a painless kit it takes out the markers and running lights..
MEMBER #6377
Project "7DEUCE"
