10-01-2007, 07:23 PM | #1 |
attn: 67 and 68 owners
Need Pictures of the radiator support mounts that are on the frame. Possibility that mine might have been hole cut to accomadate different mounts. Any pictures of virgin mounts will do me wonders.
Thanks guys, Dan |
10-01-2007, 08:22 PM | #2 |
I am a Referee of life.
Re: attn: 67 and 68 owners
If you are changing the rubber mounts with a cab mount kit that also contains the radiator supports and it doesn't look like it fits or causes alignment issues with the front end you possibly got a kit that has 69-72 radiator supports mounts.I know the kits say 67-72 but the rad sup mounts are different.
Just a thought on why you are asking.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 10-01-2007 at 08:23 PM. |
10-01-2007, 08:36 PM | #3 |
Always Fixing Things
Here are the left and right side of my '68.
Don't mind the dirt, I had some fun last weekend. The other stuff is what I call "surface rust"
Just an Average Joe ‘68 GMC 307 3spd – My dad's original truck 310,000 miles |
10-01-2007, 09:12 PM | #4 | |
Thanks for the pics but I need a pic of the hold on the mount W/O the assembly. I am curious as to the size of the hole. thanks again |
10-02-2007, 03:24 PM | #5 |
ttt
10-02-2007, 05:16 PM | #6 |
Questionable
top view:
http://satellitehead.com/images/68ch...teering002.jpg http://satellitehead.com/images/68ch...teering001.jpg Of course, the tab with the large half-dollar sized hole is the support I think you're asking about. Hope that does you wonders If not, check out my gallery and look for more pics (it's running a tad slow right now for some reason): http://satellitehead.com/gallery
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
10-02-2007, 10:16 PM | #7 | |
Thanks again dan |
10-02-2007, 11:31 PM | #8 |
Questionable
the hole is so big (i assume) so you can actually move the front clip around when you go to bolt up.
think about it - if it's a static, tiny hole to fit that 7/16" carriage bolt, you can't move it forward/back/left/right/diagonal, so it really isnt' conducive to somewhat flexible factory tolerances. this is just my thought. by the way - ALL of the body mounts on the truck are that large. All body mounts use large washers and/or rubber bushings to compensate.
