SWB 4X4 CLUB
Bench/bucket seat question
Are the seat brackets for our trucks the same for from a bench seat as the drivers side 69-72 buckets.
In other words, can I use or modify a bench seat bracket to work on my bucket seats? Jason |
I have a radical idea!
Re: Bench/bucket seat question
I'm about 90% sure they are, and if it weren't 11:00 at night I'd go outside and look.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
SWB 4X4 CLUB
Thanks 67_C-30.
Does anybody know for sure if they will work. Jason |
![]() Join Date: Jan 2007
I think the flanges at the top that bolt to the seat are different
It's a catastrophic success.
![]() Join Date: Jan 2003
Are you asking can you mount buckets on a bench frame? I would say NO because a bench only has two slide tracks where a bucket needs four. If you have blazer buckets or factory style and frame will work. Otherwize you may have to do some fabrication.
Of course your not going to have enough brackets to do all four but you can atleast do the driver seat for now..I was able to do this on my Toyota not too long ago, I used Mazda seat and bolted them to stock Toyota bench seat rail, Some fabrication was needed but overall it did work. With your situation though, I dont see you having much of a problem. Goodluck.
#7 | |
Always on the hunt...
![]() Join Date: Sep 2006
jay_shy: Here is a pic of the drivers side 69-72 factory bucket seat adjuster tracks, they are the pair on the right. Note how all four of the seat ataching points/flats are bent towards the outside edges of bucket seat and then look at your bench seat tracks for differences and needed mods. Cb
SWB 4X4 CLUB
Thanks for the picture Classic Bowties.
Here is a bench seat bracket to compare to. Jason |
SWB 4X4 CLUB
Now that I did a little searching on this site, the brackets that I posted look to be different or later model seat brackets. I will have to take a closer look when I get home tonight and compare some pics.
If somebody has some pictures of 67-72 bench seat brackets that would be great. Jason |
