10-02-2007, 02:12 AM | #1 |
Speed Limit = Floorboard
HID headlight conversion?
Just wondering if anyone has a recommedation as to where I should look for the parts to convert my 85 K10 to HID's. Anyone have this done? Where I should I look to get ballasts, headlights, bulbs etc? I'm told to use clear headlights otherwise the old style spreads the light out to much blinding others. Was thinkin 4300K bulbs in my highbeams and 6000k in my low beams. Not to worried about blinding people or getting pulled over up here, when its dark so much of the year and so many moose crossing the roads. Whats the differences between like H1 bulbs and H4 bulbs? Just the size? How involved is wiring in the ballasts? Does it just hook into the orignal harness? Not looking for the wow factor of clear "euro" headlights or blue tinted lights, but I don't want to put auxillary lights on the front, and the stock lights just don't cut it.
1971 C20 350, 4-speed - Sold. 1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project. "Build for torque, horsepower will follow" |
10-02-2007, 02:24 AM | #2 | |
Garage Queen Material
Re: HID headlight conversion?
no one makes proper HID housings for our trucks. You need a projector type housing to get the correct light pattern. If you use a stock type or clear housing without a crystal projector, it will not be safe and will blind everyone. no way in hell would the wiring plug into the stock harness. You would need to wire it directly to the battery and a seperate headlight switch. I would not trust any of the factory wiring to play any part of an HID conversion on these old trucks. in all honesty, it would be to much work and money to do a proper conversion on these trucks as of right now. i would upgrade the bulbs to say the silverstars and also upgrade the factory wiring harness to an upgraded one. both of those should make a huge difference in the light output. also think about upgrading to a higher output alternator. |
10-02-2007, 02:47 AM | #3 |
In the Forgotten far North.
When's the next time you're going to be in Anchorage? Let me know and I'll show you what I've done to my '90 burb and maybe even help set yours up for you if you wish.
I've got clear lense headlights right now but will be changing back to the better hella brand lenses this next weekend. I've also got some seriously bright bulbs in the 'burb too. H4 style 90w low beam 130w high beam
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
10-02-2007, 02:51 AM | #4 |
I agree with Ocbaud. No sense in doing it if you are going to have a broken light pattern.. and you are going to blinding everyone in your path specially on coming traffic! I have silverstars and they work great! i also have HID's in my audi from the factory they are nice.
