Adjusting Power Steering?
1971....
The power steering seems to easy? Is there a way to adjust? To make it more tighter, theres no slop in turning, the gear box was just rebuilt. Can I adjust it at the gear box? Also am putting a smaller steering wheel on. |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Adjusting Power Steering?
Not to my knowledge. There is a valve in the box that controls that, may take it back to your rebuilder. Could just take the belt off the power steering pump, that will toughen things up.LOL
Add a steering shock to your drag link just like the 4X4 guys do. That will stiffen thing up a bit as well as absorb some of the road bumps.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
theres a valve in the back of the pump, its the large fitting , where you attach the pressure line . unscrew it and try a few valves from smaller cars ( as in a camaro or chevelle or nova )it may slow it down .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
Thanks for some replys!!!
Removing the belt is a good one, LOL |
i'd just add that smaller wheel and see how you like it . if you ever put wider tires on the front ,it may be just fine .
Smaller steering wheel, I did think that that would help. Here's the steering wheel I'll put on, just don't know about the horn button? It was not the the wheel.
