10-02-2007, 12:54 PM | #1 |
6 cyl Engine Removal
Anyone have pictures of where to hook up a 250 6 cyl engine to remove it with a cherry picker? I would like to remove it and the manual 3 speed tranny at the same time if possible. Thanks
Richard Dobson |
10-02-2007, 01:52 PM | #2 |
It's a catastrophic success.
Re: 6 cyl Engine Removal
Pull the valve cover( to keep from damaging it) and remove a head bolt from front and rear of the motor and on opposite sides. Put the bolts back in through a piece of short chain, then hook hoist to chain.
10-02-2007, 02:42 PM | #3 |
Mine has two large factory looking attachment points... going to try to link to the new gallery images... if it doesn't work, I'll just post the pic... here goes....
http://67-72chevytrucks.com/gallery/...2&ppuser=19576
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
10-02-2007, 04:25 PM | #4 |
Questionable
yes.
http://satellitehead.com/gallery/thumbnails.php?album=6 and also http://satellitehead.com/gallery/thumbnails.php?album=3
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
10-02-2007, 08:18 PM | #5 |
Thanks LuvLegs & Shifty, is this board great or what. That info has made being a board member worth it. Regards
Richard Dobson |
