10-02-2007, 03:21 PM | #1 |
PITbut
Heater relocation??
71 chevy. Standard heater core in that big ugly box on the firewall. I am not running ac. Is there anyway to relocate my heater core to inside the cab without purchasing a vintage air kit??? Anyone relocated their heater core on these?
I really do not like the look of that big ugly box and am open for suggestions. |
10-02-2007, 03:54 PM | #2 |
It's a catastrophic success.
Re: Heater relocation??
You might look into the older trucks. Most had a compact heater that fit under the dash.
10-02-2007, 04:38 PM | #3 |
10-02-2007, 06:04 PM | #4 |
i've had a bunch of 30's and 40's cars and trucks that we built boxes under the seat with junkyard cores hooked up fans and had decent heat from the main problem with thatn was in the defrost deal
10-02-2007, 06:19 PM | #5 |
tractor or combine heaters work pretty good for this...
10-02-2007, 06:28 PM | #6 |
PITbut
10-02-2007, 06:32 PM | #7 |
Im not sure if you can or not. Its not impossible, just easier to find a $20 combine heater & be done with it. Give it a whirl, Id LOVE to see it done...
10-02-2007, 06:33 PM | #8 |
PITbut
10-02-2007, 07:02 PM | #9 |
combine = farm machinery.
combines multiple operations. |
10-02-2007, 07:03 PM | #10 |
PITbut
10-02-2007, 07:25 PM | #11 |
laying low
I must have missed it. I didn't see the heater on Duece's truck, only the engine side of the firewall. Hotrod heater?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-02-2007, 07:36 PM | #12 |
If you want to find an old machinery heater you are better off to find a machinery salvage yard. Heres another "could be"...
http://cgi.ebay.com/ebaymotors/Austi...QQcmdZViewItem |
10-02-2007, 07:38 PM | #13 |
10-02-2007, 07:50 PM | #14 |
Used Register
You could mount one of these off an old Willys.
http://cgi.ebay.com/ebaymotors/46-47...spagenameZWDVW My Wagon has one similar for heat and a second, separate heater/fan unit for defrost - 4 total tubes. Herb |
10-02-2007, 07:52 PM | #15 |
PITbut
On a 71 pickup. What is behind that box?? I thought it was just a heater core.. Two tubes coming in, two tubes going out. IS there more to it then that???
10-02-2007, 07:56 PM | #16 |
I am a Referee of life.
Check out the J.C.Whitney catalog.IIRC they have one for buses,vans and such that is pretty compact.It's been a while since I looked.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-02-2007, 07:57 PM | #17 |
Get one of these. They also sell a defroster kit for it. They work pretty good. I've used them in 3 different vehicles I've built.
http://www.jegs.com/webapp/wcs/store...10002_84112_-1 |
10-02-2007, 07:59 PM | #18 | |
PITbut
I wonder if vintage air sells just a heating setup for our trucks?? Back to searching |
10-02-2007, 08:01 PM | #19 | |
PITbut
Thanks for the link. |
10-02-2007, 08:05 PM | #20 |
10-02-2007, 08:09 PM | #21 |
PITbut
10-02-2007, 08:10 PM | #22 |
PITbut
10-02-2007, 08:14 PM | #23 |
Active Member
I think he means to get the plenum asm. Click on the link below the actual picture that says. For a complete list of Flex-a-lite Mojave Heater Assembly, click here. Last edited by 68gmsee; 10-02-2007 at 08:16 PM. |
10-02-2007, 08:16 PM | #24 |
10-02-2007, 08:24 PM | #25 | |
PITbut
IIRC means, if i remember correctly??? |
