Old 10-02-2007, 06:21 PM   #1
Primered_69
Primered_69's Avatar
Tech: Blazer Tank Conversion Fuel Filler Delete
Materials Needed:
1. Fuel Filler blank (Got mine here http://myworld.ebay.com/infanti72 but he is a site vender www.infantirides.com)
2. Fuel filler rubber grommet (can use current on or get new one)
3. Bolt (2 1/2"), washer, and wing nut
4. Old 4.5 grinding disc
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 10-02-2007, 06:21 PM   #2
Primered_69
Re: Tech: Blazer Tank Conversion Fuel Filler Delete
Step 1: Weld or epoxy bolt to back of the fuel filler blank (see picture above)
Step 2: Paint old grinding disk to use as a backer for inside of delete and to not look too ghetto from inside.
Old 10-02-2007, 06:21 PM   #3
Primered_69
Step 3: Install rubber fuel neck filler grommet w/ cone side of grommet on the inside of the truck and the flat side on the outside.
Step 4: Insert fuel filler delete with the bolt going into cab.
Old 10-02-2007, 06:22 PM   #4
Primered_69
Step Five: On the inside of cab insert old grinding disk with flat side first on then bolt, then washer, then wing nut. Tighten
Step five: Here is what you end up with. (I left blank unpainted for demonstration purposes.)
Old 10-02-2007, 07:15 PM   #5
Primered_69
If you want to you can add a bead of silicone before you tighten the delete down all the way.
Old 10-03-2007, 12:43 AM   #6
Infanti
www.infantimachine.com
Infanti's Avatar
Good thinking Primered_69,very ingenious. Another option other than welding the hole up , good job.
Infanti is offline   Reply With Quote
Old 10-03-2007, 04:00 AM   #7
earl87gta
earl87gta's Avatar
that would work good with the body pannel adhesive that they use now instead of welding.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
