![]() Join Date: Jan 2006
Question about engine hoist
I am in the process of a engine swap and was wondering if a 1 ton engine hoist is sufficient enough to remove and install a V8 small block? Anyone use the harbor freight hoist shown below?........thanks rick
Re: Question about engine hoist
I was looking at those too, and I would think they would be fine - your motor doesn't weigh near anywhere a ton.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Always on the hunt...
That will handle the job just fine. I have a proven, similar model picker that's been well used. Cb
![]() Join Date: Apr 2004
I have one very similar to that. I've used it many, many times. You will be fine.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
blood type; Retumbo
I got a similar one from Sam's Club. IIRC it was $170 out the door. no shipping or any extra costs. I made a longer boom for it and hung a full dressed BBC for a TopKick into place with not a single problem.
i used one just like that for my engine, cab and box
common sense isn't so common anymore |
![]() Join Date: Jun 2007
I've got one like that from harbor freight, but mine is a 2 ton. As the boom is extended the capacity decreases. I was on the third hole when I changed the motor in my c20 and the capacitywas down to 1000lbs. You might want to check this before you buy.
Don |
Any idea on the weight of these motors?
i've got the 2 ton as well, and was about to type the same thing don did : ) with a truck you've gotta extend it pretty far, and, better safe than sorry : )
small block plus tranny is less than 1000lbs.
They work good, only problem I've encountered is after sitting unused the cylinder starts to leak, also had one cylinder go bad, however a quality cylinder can be picked up cheap at any farm store.
A sweet 2000 Deville..... |
![]() Join Date: Feb 2004
A word of advice get the 2 ton or atleast when you go to remove your motor, remove the hood or go simple and remove the front clip really easy and quick. only like 10 bolts. do a search in the FAQ and you can see how it is done in detail
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#13 |
i've seen more than a few posts about the cheapass harbor freight stuff buckleing under load with tools you generally get what you pay for
#14 |
Truck and auto performance nut
I also have a 2 ton. I had to have it on the last bolt to get the boom far enough out to pull my V6 and lay it on a trailer. At full extension...my 2ton crane is down to 1/2 ton. So a 1ton would be down to 1/4 ton at full extension...which you need if you have to go deep in or up high over something.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#15 |
blood type; Retumbo
there was a thread here a couple years ago about someone's cheap hoist bending under small load. there were pics showing what to look out for when shopping for a hoist. IIRC it was purchased from Pep Boys if that helps for the search.
#16 |
Look around just a bit more - I have one that looks just like that one but red and 2 ton - if you look around, you can also find that one with the load leveler included. I think I got mine at northern tool - about $175 - largest lift was a fully dressed 318 - fully extended, no problems..(on CONCRETE)
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
#17 |
Also keep an eye out for sale flyyer from HF. I just bought thier 2 ton folding hoist for $147 plus had a 15% off coupon...then a buddy went in for half with me
#18 |
doesnt matter any ways. you will most likely have to extend it all the way out to reach the engine which on a 2 is still 1/2 ton.
#19 |
Mine came with the leveler deal. I got it at Northern Tool for under $200 with tax.
The leveler is a worm gear deal that will balance your engine or tip it while it is hanging.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#20 |
67 is sold
That portable unit looks just like mine, we've swapped a few motors and have moved my cab a few times with it
#21 |
...Or you can just rent a good one...
#22 |
yeller
I have the exact same one, it did a great job helping me install the 454/700r4 into my truck.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#23 |
I got that exact one for my project, I would even pull a big block with it. Didn't have any problems......
1997 GMC Sierra Ext 1965 Mustang |
#24 |
~Rest In Peace~
craiglist i got mine from and sbc engine weight about 700lbs
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#25 |
You should check any local tool stores. I got a 2 ton about 9 years ago and don't use it often. I believe it is Larin brand and it has never leaked. Spring for the leveler if it isn't included. It's well worth it because trying to muscle an engine to mate to a tranny isn't fun.
| Bookmarks |
