Old 10-03-2007, 01:13 PM   #1
kyull67
kyull67's Avatar
Question Mufflers for the 250cid Six banger?
I just bought the clifford split headers, offenhauser intake, and a Holley 390cfm Carb. Now I'm getting ready to buy mufflers. In your opinion what is the best muffler to go with for both sound and performance with my split headers?
Thanks.
kyull67 is offline   Reply With Quote
Old 10-03-2007, 02:59 PM   #2
Texasdeere
Texasdeere's Avatar
Re: Mufflers for the 250cid Six banger?
Were you planning on a dual system or a single pipe?
How loud do you want it?
I think best performance and sound will be with a single 2.5" system. The muffler depends on the type of sound you want.
Texasdeere is offline   Reply With Quote
Old 10-03-2007, 03:16 PM   #3
kyull67
kyull67's Avatar
I think it would be best to run duals. The header is split; cylinders 1-3 out of the first collector and cylinders 4-6 out of the second. I've heard people talk about the unique sound of a "split six" so I want to go for that. As far as noise level, I want it to be fairly loud. What are some of you other straight six guys using for mufflers?
Old 10-03-2007, 03:47 PM   #4
nplocoman
never finish start another
nplocoman's Avatar
On my 292 turbos sound terrible
nplocoman is offline   Reply With Quote
Old 10-03-2007, 03:54 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I worked PT at a muffler and brake shop for 3 years. I would run everything out 2
where the mufflers are going to be. Use a couple of stands and a few rags. Get a
person up in your truck. Have them hold up different mufflers that are available &
use the rags to rap around the front connection. We did this on GQ, I went from
wanting Flowmasters to buying Magnaflows* without even blinking. A GOOD SHOP
is willing to do this, most shops won't bother unboxing 2 of each. Make sure they
goose it a few times on each to hear the different sound levels. Hope this helps
*I have Magnaflows on GQ, but MERLOT will have Borlas
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-03-2007, 04:23 PM   #6
kyull67
kyull67's Avatar
That's a great idea! Why didn't I think of that?
Thanks.
Old 10-03-2007, 04:26 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
No idea
Old 10-03-2007, 05:10 PM   #8
Boog
laying low
Boog's Avatar
I vote for a pair of the old time Smittys mufflers or just a pair of store bought glass packs with 2 1/4" pipes all the way out the back. Yeah, it'll talk to ya.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-06-2007, 05:28 PM   #9
chvtrkman
chvtrkman's Avatar
I'm running a pair of Summit Racing welded mufflers (Summit part# 633222) through 2 1/2" pipes in/out.
They are reasonable at idle but when you rev it up they are a bit louder than what I wanted. Sound good though.....almost like a WW II fighter plane. This is on a 292....I imagine they would be similar on a 250.
69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt"
78 C-10 305 TH350 new (old) daily driver
02 Suburban Z71 a.k.a. the family truckster
99 Silverado 1500 Z71
chvtrkman is offline   Reply With Quote
Old 10-06-2007, 06:09 PM   #10
samwise68
FarmBoy.
samwise68's Avatar
i say glasspacks, especially with the split six sound.
it works out so that the firing order has a cylinder firing in the alternating pipe.
1-5-3-6-2-4.
so, front-back-front-back-front-back.
hense. that lovely sound known as split six. .
should be a snappy engine. and i stand by the 'packs for it.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 10-06-2007, 08:17 PM   #11
JAKES 68GMC
Aluminum slot wheels rule...
I vote for Smithys, I heard them on a 216 Chevy that had cast-iron headers and dual 1-barrels. It was the sweetest sound I've ever heard.
JAKES 68GMC is offline   Reply With Quote
Old 10-06-2007, 09:43 PM   #12
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: Mufflers for the 250cid Six banger?
12 inch glasspacks, turned backwards, as close as possible to the collectors, 1 3/4 inch tailpipes as straight as possible out the back. that S.O.B. will rattle windows for 3 blocks. this is if you want it LOUD.
a pair of longer glasspacks farther back with 2 inch tailpipes will be nice and mellow.
been in the same muffler shop almost 23 years now and done several old chevys with split 6's, the first way is loud enough to draw attention from every cop in town
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 10-06-2007, 10:49 PM   #13
67_C-30
I have a radical idea!
67_C-30's Avatar
I heard a split 6 header on a 250 with dual chambered muffler like what came on 69 Z28's, and it sounded wicked. You can get these here:
http://www.classicchambered.com/classic/sounds.html
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-07-2007, 11:07 PM   #14
Big D
Big D's Avatar
I'm running a thrush turbo on mine, It had one of those bargin 18" glass-packs on it when I got it and it sounded like a vacumn cleaner on steriods. The turbo gives it a nice throaty sound.
68 GMC
64 1/2 Mustang convert
A bachelor's life is no life for a single man."
- Samuel Goldwyn
Big D is offline   Reply With Quote
