10-03-2007, 04:33 PM | #1 |
Back-Up Lights
I'm pulling my hair out trying to figure out my back-up lights, they just don't work period, I am not getting any power back to the lights, fuse is ok, lights are brand new and I bench checked them before I installed. Where should I start looking? BTW, I have a 68 stepside LWB,
GBWatts 68 C10 Stepside LWB Howell, MI |
10-03-2007, 04:44 PM | #2 |
Re: Back-Up Lights
Is the reverse switch hooked up? If the truck is an automatice or 3 speed manual the switch should be on the column. For a 4 speed I believe it is on the transmission.
You can take the wires off the switch and with a test light you should have power to one side of the switch. If you do, then use a jumper wire and put power across and eliminate the switch, and if they work now you probably have a bad switch.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
10-03-2007, 05:06 PM | #3 |
Re: Back-Up Lights
The lights also need to be grounded to the bed. There should be a ground strap from the bed to the frame. If your truck has been repainted, there may no longer be a metal to metal contact.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-03-2007 at 05:06 PM. |
10-03-2007, 07:28 PM | #4 |
I am a Referee of life.
Re: Back-Up Lights
Mine did not work when I got the truck.I used a nutdriver(5/16 I think?) and adjusted the backup light switch.Took all of about 5 min once I figured out the problem.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-03-2007, 11:30 PM | #5 |
Re: Back-Up Lights
i just fixed mine yesterday by ajusting the neutral safty switch
common sense isn't so common anymore |
