Kick Panel Vent removal?
on a non air truck, are these vents really nessasary or could i just wall them in. (no more vent ) i don't plan to alter the ventilation system in any other way, but am i about to mess up?
i survived cancer and kidney stones, but my kids are killing me. |
Re: Kick Panel Vent removal?
I think they are nice to let fresh air into the foot area. Why do you want to cover them?
i agree i like them and i think using them helps to dry out the lower cowl area
common sense isn't so common anymore |
![]() Join Date: Mar 2007
I think you should take them out. I need the parts for the pass. side of my truck.
![]() Join Date: Jun 2002
I have seen trucks with them blocked by panels or speakers and don't see how it could be a problem. It's no different than driving with them closed. The only problem would be having no way to clean up the leaves and crap that get in there, but you could clean them out well and put a screen under your cowl panel to keep them clean.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
![]() Join Date: Nov 2004
You HAVE to block off the passenger side if you use a sure fit vintage air kit. I do find it nice to open the DS one on days when I don't need the windows down for fresh air.
Don't really see it as a problem, although I haven't driven in cold weather yet... may need the fresh air to keep the cab from fogging up?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-04-2007 at 10:51 AM. |
![]() Join Date: Feb 2004
well i fabbed up metal kick panels with no vents and then i cut off the bottom portion of the vent behind the front fender. this way if leaves go in the cowl they will drop out on the ground under the truck and not stay in there to collect moister, hopfully this prevents me from replacing the cab pillar,rocker , floor,kick panel and front cab support again. those vents are the prime suspect when it comes to finding a culprit for the typical rust areas of these trucks...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
depends on what kind of motor your running,
I've got a 383 stroker motor, with headers (runs close to the floor), and i know that if im driving on a hot summer day, and i forget to open the vents, my feet get real hot, real quick. non air trucks had crappy venilation down there, and it gets quite un-comfortable.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
