All, my volt meter is pegged at 18 volts whlie driving, when I turn the lights or any other electrical item on, volts drop to 14, then surge back and forth from 14 to 18. Lights in the truck get brighter and dimmer when the volts surge. New battery and voltage regulator, could this be a bad altenator. Please help electrical is so frustrating.
![]() Join Date: Jul 2007
Re: Electrical Gremlins Please Help
I would think so easy check there are a lot of battery/service statations that do free alt checks be an easy way to cross it off the list at worst
Overdrive club
Sure does sound like a faulty regulator!!!!!!!
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
huh?
![]() Join Date: May 2000
Have you been able to verify the 18 volts at the battery, with the truck running? I've had extremely limited experience with an external voltage regulator, so I can't be of much help, but I will say it sounds like a definite overcharging problem via your gauge. It would be best to verify the voltage at the battery if you haven't already done so, and go from there.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
i like gremlins
Retired Air Force 87-09
It sounds like the voltage regulator. You neglected to mention if it is external or you upgraded to an alternator with an internal regulator. I have heard that you could repair an external regulator. An internal one cannot be repaired, it would need to be replaced.
laying low
![]() Join Date: Mar 2001
Cdowns. I can't think of a better use for a Gremlin.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
