Old 10-03-2007, 09:13 PM   #1
1972Ryan
6cyl power steering lines
I need the two lines that go to the power steering pump on my 250 6 cylinder.....Do you guys know if that is something I can pick up at the local parts house or something I will need to find?
1972Ryan is offline   Reply With Quote
Old 10-03-2007, 09:23 PM   #2
Luvlegs
Luvlegs's Avatar
Re: 6cyl power steering lines
I can tell you the exact part # I bought at Advance auto - it'll take me about 5 minutes to go check.... it's both hoses and an adapter fitting.... gimme a sec or two....
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 10-03-2007, 09:35 PM   #3
Luvlegs
Luvlegs's Avatar
71065 is the number on the box - made by powercraft - silverish box with blue hose picture on it. It comes with a brass fitting you screw in the back of the pump (not the steering box) - they look like this.....
http://67-72chevytrucks.com/gallery/...4&ppuser=19576
http://67-72chevytrucks.com/gallery/...3&ppuser=19576
The return hose is just a hose - you'll need something to connect it on the box end - I had another hose that was bad, cut the end off, flared it in a flaring tool, slid the hose over and clamped it (you can see the discolored fitting in the second pic. The other end slips over the return pipe already on the pump.
1972 C10 L6 3OTT
